vibration when start to move
Discussion in 'Camelback Toyota Parts' started by tacomatato, Apr 27, 2012.
  1. Apr 27, 2012 at 2:37 PM
    tacomatato
    tacomatato [OP] New Member
    Lawrence,MA 01841
    05 SR5
    I own tacoma 2005 with 76k miles that is starting to vibrate when it starts moving. The mechanic said that I would need to replace the shaft drive. Does anyone have any idea of what it could be? or has had the same issue? where can I find the shaft drive?
  2. Apr 30, 2012 at 7:06 AM
    Jorge@CBTParts
    Jorge@CBTParts Well-Known Member
    Jorge
    Phoenix, AZ
    Can you PM your VIN? Did your mechanic actually inspect the vehicle or was this something that he suggested without looking at it?
  3. Apr 30, 2012 at 7:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What dealership did you take it to? Some of the Toyota dealerships up here are 'less qualified' than others. There's on in Acton that has a very good reputation.
    When you get the vibration, is it just when you slowly start to roll off the line? Does it happen only under hard acceleration or does it vibrate when softly accelerating as well? Does it go away at speed? Any stray noises?
    I doubt it's your drive shaft that's defective... It's most likely a drive line component, either a bad u-joint, carrier bearing or even a worn out leaf pack causing axle wrap but I doubt the drive shaft is the problem for a slow speed vibration.
