Vibration when turning left
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 650H1, Dec 23, 2011.
  1. Dec 23, 2011 at 1:53 PM
    650H1
    650H1 [OP] Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    So my truck has a vibration when turning left at 55 or faster, wtf is it!! Wheel bearing? What side?
  2. Dec 23, 2011 at 6:57 PM
    650H1
    Michael
    VA
    Bump
  3. Dec 24, 2011 at 6:19 PM
    650H1
    Michael
    VA
    I have ome 884x coils and fab tech 1.5 inch aal's. Tires are stock 265 65 17's for winter. It only does it when turning left if you go straight or right it's fine.
  4. Dec 24, 2011 at 6:22 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Wheel bearings already with an almost new truck?
    Are you on stock wheels? Have you had any accidents?
  5. Dec 25, 2011 at 4:09 AM
    650H1
    Michael
    VA
    Im Trd sport wheels. When I'm turning and it's making the noise there is a small pause every 2 seconds but when I'm driving straight or right or below 55, there is NO noise. I hit a curb really hard in a snow storm back in October and have trying to track it down since then. I've rebuilt the drivers side cv joint, and replaced the drivers side wheel bearing just throwing parts at it but I'm thinking the passenger side wheel bearing is junk. I had the wheels turned and was sliding when I hit the curb so the pass side front wheel hit it straight on, i didn't just drive up on the curb. It brought the truck to a stop but I never saw anything broken had it aligned and nothing was bent everywhere I go says it looks fine and they don't hear anything with a stethoscope in the hubs...
  6. Dec 25, 2011 at 11:48 AM
    Tacoma Mike
    Southern Maine
    Swap the front tires and drive..........
  7. Dec 25, 2011 at 1:24 PM
    650H1
    Michael
    VA
    Everyone blames it on the tires at every garage I went to. It was so bad that I got a set of stock 265 65 17 geolanders and what do you know? Noise is still there. It's not a tire noise it's like a harmonic vibration specifically only when I turn left going faster than 55. That is the only time it does it.
  8. Dec 25, 2011 at 1:36 PM
    Tacoma Mike
    Southern Maine
    would have been nice to have this info in your first post.
  9. Dec 25, 2011 at 1:40 PM
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    Didn't notice if you said it already but have you thoroughly checked the wheels to see if they may have warped during the impact?? Being just slightly out of round will cause vibrations and it intensifies with speed or when turning as you describe.
    Not saying that is your problem but may need looking into. A good tire/wheel shop can tell you if a wheel is warped.
  10. Dec 25, 2011 at 9:29 PM
    650H1
    Michael
    VA
    I bought new wheels and tires off of a Trd sport these aren't the ones I hit it with.
  11. Dec 26, 2011 at 7:35 AM
    650H1
    Michael
    VA
    Anyone?
  12. Dec 26, 2011 at 12:52 PM
    Tacoma Mike
    Southern Maine
    Trying to listen with a stethoscope does not always get you the result.
    Being up on a lift rotating does not load the bearing.
    The bearing is 2 sets of rollers. One of the outside balls could be getting ruff and when you load to the left that roller comes into play.
    It's possible hitting the curb deformed one of the balls but I can't say for sure.. Bearings can go out for no apparent reason....
    A set of chassis ears could get you closer to the area that it is.
    It's a 2011 Get it back to the dealer or another dealer and go for a ride with someone and point it out. It's the only way to start right now.......
    Vibes and noises are not the easiest things to track sometimes......
  13. Dec 26, 2011 at 12:59 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    my guess is your cv boot
  14. Dec 26, 2011 at 1:06 PM
    jandrews
    '09 FourDubDee TRD OR
    Just make three rights instead. Problem solved. You're welcome.
  15. Dec 26, 2011 at 2:52 PM
    650H1
    Michael
    VA
    I had that fixed, and they replaced the drivers side bearing under warranty. The only other thing it could be is the pass side bearing
  16. Dec 26, 2011 at 5:40 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    or they didn't actually fix anything and charged you for it. look under your truck.
  17. Dec 27, 2011 at 3:23 PM
    650H1
    Michael
    VA
    Turns out it was the pass side wheel bearing took it to another dealer and they took care of it
  18. Dec 27, 2011 at 4:26 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    sweet. at least they fixed it and didn't blame it on your tires or something.
  19. Dec 28, 2011 at 4:21 PM
    650H1
    Michael
    VA
    Haha yea dude 1 for 3 isn't bad
