Vibration when using more torque
Discussion in '1st Gen. Tacomas (1995-2004)' started by Leadgolem, Apr 25, 2010.
  1. Apr 25, 2010 at 12:28 AM
    Leadgolem
    Leadgolem [OP] Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    I'm getting a strange vibration when I need more torque. The degree of the vibration seems to be conversant with the level of torque needed. IE: Climbing a hill, or if I shift up while cruising to save gas. I was wondering where I should be looking for the issue.
    98 taco, sr5, no lift, 31x10.5 tires, 2.7L 5spd stick.
  2. Apr 25, 2010 at 11:46 PM
    JManders
    JManders Assistant to the Regional Manager
    Jon
    Fort Collins, CO
    2k Black SR5 TRD romper
    Warn driving lights, Aries brush guard, tow package, removed mudflaps, Uniden CB radio, Firestik antenna, PA horn, deck plate mod, K&N air filter, blacked-out badges, Hella SuperTone horns, 20% tint all around, fog light mod
    I get the same kind of thing going on with my 2000... I noticed that i get a fluttering sound coming from the glove box area when I'm climbing a hill, especially on the highway in the mountains. Are you getting the same kind of thing or just a vibration.
  3. Apr 25, 2010 at 11:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    On worn out spark plugs (too wide a gap), the spark can blow out under load (climbing a hill). Could your vibration be a high speed miss?
  4. Apr 26, 2010 at 12:22 AM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    Spark blow out / ignition miss should trigger the CEL on an OBDII.
    Is your check engine light on?
    If not a engine running issue I'd look into drive line / U-joints / drive line mounts motor and trans ect...
  5. Apr 27, 2010 at 12:18 AM
    Leadgolem
    Greg
    Littleton, CO
    No Check engine light, no glove box flutter.
    Unfortunately I'm fairly sure I know what the issue is. Seems like my clutch is slipping. I shifted from 4th down to first with the clutch pushed all the way in and it ground. *sigh* That will put a damper on my mod plans...
  6. Apr 27, 2010 at 12:27 AM
    Whitfield
    Central Virginia
    That 4th to 1st grind has nothing to do with the clutch slipping.
    That sounds more like a hydro clutch master / slave issue. Have you had to add any fluid to the Hydro clutch resevior lately? Any trace of a fluid beard leak from the clutch master or slave unit.
  7. Apr 27, 2010 at 12:35 AM
    Leadgolem
    Greg
    Littleton, CO
    Yup, there's a leak. Must not be a particularly fast one though. I haven't had to add fluid and it's not low.
  8. Apr 27, 2010 at 1:03 AM
    Leadgolem
    Greg
    Littleton, CO
    With just the vibration to track down I was hoping to do the diagnosis and fixing myself, but with a transmission issue of any kind I think this means a trip to a mechanic.
    Thanks though.
    EDIT: I guess transmission issues would also be why I had a little trouble getting it out of 4wd last time I used it too...
  9. May 4, 2010 at 3:21 AM
    Leadgolem
    Greg
    Littleton, CO
    Transmissions been scoped, no issues there. :) Leakage was old. Vibration was caused by a destroyed U joint and a damaged yoke. Should have my truck back later today from the mechanic.
