vibration while braking?
Discussion in '4 Cylinder' started by mcleod90, Dec 19, 2010.
  1. Dec 19, 2010 at 5:34 PM
    mcleod90
    mcleod90 [OP] 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    i bought my truck brand new about a month ago. and ive noticed sometimes when i brake it feels like the back wheels are shaking. it mainly happens if i slow down to turn and occasionally when i come to a complete stop. is this normal or should i take it back to have them look at it?
  2. Dec 19, 2010 at 5:52 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    More info is needed, you bought a truck brand new a month ago doesn;t say much about what it is you are driving bro'... just my .02 :D
    & more info on the condition you describe , but yeah in any event if its still warranteed (month old obviously it is) Take it back to the dealer & document EVERYTHING its tedious & time consuming but can quite literally save your ass down the road if it isn't remedied... good luck..
  3. Dec 19, 2010 at 6:09 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    its a 4 cylinder 5 lugger. has about 700 miles on it
    it feels like the tires are out of balance when i brake. it only happens a few times. it is still warranted so ill give them a call tomorrow.
    if it is the rotors how did they get warped so fast?
  4. Dec 19, 2010 at 6:34 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    Just take it in if it under warranty. Hell they may even wash it for you.
  5. Dec 19, 2010 at 11:49 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well, first off, you need to pin point where this vibration/noise is coming from, if its from the back, I doubt that it'd be rotors (even if it was 4 wheel disc brakes ) 80-plus percent of stopping power comes from the front brakes, those being disc , it is rare but on occasion sometimes if some very hard ,prolonged braking occurs you can heat the rotors too much.too quickly & warping and/or rotor "run out" can happen, but like I said , I'd def. take it back to the dealer before getting one fingernail greasy, that manu. warranty is a good chunk of what you pay for when buying a new vehicle, I was thinking maybe axle-wrap , your truck being so new (is it considered a 2010 or 2011 ?) I'd check into any TSB's being done to other year models like yours or any pending.... just my .02....good luck...:cool:
  6. Dec 20, 2010 at 3:12 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    does this happen only when you brake really hard?
  7. Dec 20, 2010 at 5:39 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    If it "only happens a few times", that could be a loose wheel or hub or some drivetrain part. Even a new low mile tire, that might have separated or was sidewall belt bruised, will feel like a intermittent warped rotor.
    Definitely run it back down to the dealer and explain that.
    You can warp rotors pretty fast, even when new and thick. they require easy break pedal applications for the first 500-700 miles,,but if this is a intermittent problem,,I would suspect something else. Warped rotors will shake the truck every time you put your foot on the brake pedal.
  8. Dec 20, 2010 at 5:43 AM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    My rig does the low frequency vibration noticeably when slowing down from 50mph and above. I'm pretty sure it's warped rotors, since if I'm looking for it I can feel it at most other speeds.
  9. Dec 20, 2010 at 6:02 AM
    bishtacova
    bishtacova Don't buy a Ford
    2009 DC PreRunner V6
    4 leaf TSB, reflash ECM, Eurostyle antenna, thule roof rack, bed extender
    I had my rear brake drums replaced as I noticed a vibe in the seat. Took care of most of the vibes from the truck. The entire rear brake drums are one piece replacements,take the service writer for a drive to feel it.
  10. Dec 20, 2010 at 4:57 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    Having the truck looked at on Wednesday. I'll keep you guys posted.
  11. Dec 22, 2010 at 9:01 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    ABS!
  12. Dec 22, 2010 at 9:28 AM
    danstacoma
    danstacoma Well-Known Member
    Dan
    pa
    07 Tacoma
    3 inch lift, painted badges, k&n cold air, cherry bomb, tinted windows, yellow fogs, and more to come
    sounds like warped rotors maybe......
  13. Dec 22, 2010 at 4:14 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    I had to reschedule to a day I'm off work which is next wednesday but I'll be sure to update you guys on what they say.
  14. Jan 16, 2011 at 4:43 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    i've noticed sort of the same thing except mine only tends to happen when im decelerating and the rpm reaches about 1000. i thought it was brakes too but then i felt it a couple of times when i wasnt touching the brakes. have you felt it at all when the brakes arent applied? mine just rolled over to 1000miles today. but ive only had it 2 weeks
  15. Jan 16, 2011 at 7:19 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    Mine is just when I brake. I havent had a chance to take it in but I plan on doing it this week or next.
  16. Jan 16, 2011 at 10:31 PM
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    my 05 does the same thing. when I posted and asked everyone said either warped rotors or that its normal. I have the 4 cylinder also. But i dont know what it really is. Same symptoms as your saying. I'd be interested in seeing what toyota says to you
