Vibration while creeping in reverse
Discussion in '4 Cylinder' started by GatorBodine, Sep 12, 2023.
  1. Sep 12, 2023 at 6:41 PM
    GatorBodine
    GatorBodine [OP] Well-Known Member
    Jay
    23' 4 cyl.
    Wondering if this is a normal characteristic of the 4 cyl? I got a brand new 3rd gen, 4 banger and I have vibration as I slowly creep backwards in reverse. Basically no foot on the throttle. When I add throttle and speed up it smooths out.
  2. Sep 12, 2023 at 8:17 PM
    AgentCovert
    AgentCovert Well-Known Member
    22 SR5 DCSB 2.7L
    I'd at least mention it at the free oil change unless it gets worse before that..the 2TR-FE model does make sounds at times from heat shields vibrating during shifting that are more sounds or tones then any felt vibrations..Yes not what your question was but it's worth mentioning perhaps as its a very distinct sound around shifting periods that apparently is a non issue when people tell the Stealership about it..I myself haven't noticed a vibration while reversing in my 22 DCSB with 10k miles on it..
  3. Sep 12, 2023 at 8:33 PM
    Zerksees
    Zerksees Well-Known Member
    2017 Access Cab SR 2.7L M/T 4WD
    Sounds normal to me.
  4. Sep 13, 2023 at 2:26 PM
    GatorBodine
    Jay
    23' 4 cyl.
    You have/had that with yours?
  5. Sep 14, 2023 at 8:24 AM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Mine does that as well I also have a trd front skid and some cat shields. Always thought it might be one of them but maybe not. I have the same sound if you find anything post it up. You really need two people to find the cause of the rattle it’s only in reverse
  6. Sep 14, 2023 at 10:07 AM
    GatorBodine
    Jay
    23' 4 cyl.
    I'm not getting a rattle, it's a vibration
  7. Sep 14, 2023 at 10:28 AM
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Rattle/Vibration same thing in my book but mine has the sound in reverse only
  8. Sep 14, 2023 at 5:30 PM
    GatorBodine
    Jay
    23' 4 cyl.
    I stopped in the dealer today to pick up tags and spoke the service dept. They had a tech check it out as he has a 2.7L 2WD and he said his is the same. Seems to be just a characteristic of the drive train.
  9. Sep 14, 2023 at 6:44 PM
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    It never bothered me enough you really need to have some one just lay down by the truck and back up slow, something is vibrating or maybe its a slight clearance issue. Its also seems like turning while backing up changes the noise on and off.
  10. Sep 15, 2023 at 6:16 PM
    TonyG2
    TonyG2 Active Member
    2020 Tacoma SX
    Mine does it. Worse with AC on
    GatorBodine[OP] likes this.
  11. Sep 16, 2023 at 5:31 AM
    Zerksees
    Yes. I've found the 2.7 doesn't really like to be lugged down to anything less than 1500rpm, unless you're going downhill and using engine braking.
  12. Sep 22, 2023 at 4:22 AM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    I have a vibration too when going slow/lugging the truck. It comes from passenger side front end somewhere, it is annoying. Not sure if its the same as you guys speak of, but its there. Truck is manual transmission and lifted w skid plates. I need to solve it.
