Vibration with new tires above 55mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cardsallday13, May 5, 2019.
  1. May 5, 2019 at 6:51 PM
    Cardsallday13
    Cardsallday13 [OP] Well-Known Member
    2017 DCSB TRD Sport 4x4
    Hi all. Forgive me if this has already been asked. I did search around a bit but didn't see anything specifically the same as mine (watch someone find a thread)...
    Anyway i have a 17 TRD sport. Has the 17in wheels with stock 265/65/R17 tires. OEM was Toyo Open Country A30s. They needed to be replaced so I had a local chain tire shop mount/install, etc. Michelin Defender LTX stock size. This past thursday.
    I immediately had an issue with vibration in the steering wheel, truck/seats at roughly 55mph+.
    The shop i bought the tires from said they had balanced the tires, so i took it to another shop and had them balance. Still vibration. I took it to a different location of the same chain that first installed the tires (closer to my house and open on the weekend).
    Long story short, since Thursday the tires have been balanced (road force) 4 times and have actually been swapped with another set of the same michelin tires and still no luck.
    SO. as of right now, the shop manager will be installing yokohama geolander h/ts and seeing if that works.
    This leads me to a couple questions if TW land could help a fellow owner out.
    1. Has anyone ever run into this issue? I never asked if they did an alignment, but i haven't had any pulling one way or another while driving so didn't think about it.
    2. Could it be anything else? Didn't start until the new tires were installed.
    3. Is the open country A30 the only tire that toyota put on the TRD Sports? I may have to go back to an OEM tire and would like know if they had any better options.
    Thanks all. Needless to say this has been quite frustrating.
  2. May 5, 2019 at 7:30 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    I don’t think it’s alignment since you didn’t change anything, but at this rate I don’t see how checking it would hurt? They could’ve knocked something just right to throw it off just enough to make a difference
  3. May 5, 2019 at 7:34 PM
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    A technician putting a wheel back onto the vehicle hard enough to change his alignment?
    Skydvrr likes this.
  4. May 5, 2019 at 7:36 PM
    BlackGT99
    Noel
    One or more tires could be out of round?
    ridefreak and OnHartung'sRoad like this.
  5. May 5, 2019 at 7:39 PM
    Cardsallday13
    Maybe. But they have gone through 8 tires and wouldn't the road force balancijg machine tell them that?
    TheGoat likes this.
  6. May 5, 2019 at 7:43 PM
    jmauvais
    NorCal
    ...stuff
    In my experience, a lot of tire shops are staffed my inexperienced morons. Are you really asking this question?
  7. May 5, 2019 at 7:44 PM
    BlackGT99
    Noel
    Yes I am.
    Skydvrr likes this.
  8. May 5, 2019 at 7:45 PM
    BlackGT99
    Noel
    Yes road force would tell you that information.
  9. May 5, 2019 at 7:46 PM
    Cardsallday13
    How did the title of the thread get changed?
  10. May 6, 2019 at 1:50 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Make sure the company is using a Haweka adapter that is made for Toyota wheels to get a proper balance. If not used you will always have an issue. Check the build date on the tire and make sure they are fairly new. Should be 4 numbers. The first is the week and last two are the year. Example 0119 week one of 2019. The tires could have been sitting in a hot ass warehouse. Something also to check is make sure they tortured the wheels to spec and not using an impact.
  11. May 6, 2019 at 5:09 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    New tires are never perfectly round. To get close to that you can have them trued, and then balanced. Not all tire shops have this equipment. I'd check into that.
    Tire Truing/Shaving
    A process using a lathe-type machine to gently shave off excess rubber eliminating flat spots and “out-of-roundness” rendering a perfectly round tire that can then be high speed balanced properly
    OnHartung'sRoad likes this.
  12. May 6, 2019 at 5:25 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Toyota uses special weights because the clearance between the brake caliper and the wheel is very tight. Most tire shop 'low profile' weights are bigger. My guess is they are balanced on the machine then a weight gets knocked off after the wheel is bolted to the truck.
    We're all just guessing though. If the tire/wheel combination is passing a road force balance test then it is time to look at the hub.
    It is foolish to get new tires without getting an alignment but most alignment problems cause steering issues (wandering, etc) and uneven tire wear not vibrations.
  13. May 6, 2019 at 5:31 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    A shot shock absorber can give you wheel vibration as well. The vibration would be localized to the one corner with the shot shock.
    The easiest way to check for a shot shock is to press down on each fender and watch it bounce back: it should come back once and stay there. If you see a corner go up and down 2 or 3 times, you got a shot shock.
    Good luck.
  14. May 6, 2019 at 5:32 AM
    gitacotrd
    gitacotrd Well-Known Member
    Marc
    Texas
    2018 Cement TRD offroad
    Avid lightbar, Eibach 2in lift, various TRD parts
    Had same issues with 2 sets of falken wildpeaks... some tires have dots that are suppose to be aligned with the valve stem... look for that... also some tire brands just suck... but I had the same issue over 60 mph vibe... switched to Ko2’s no issue
    InfernoChalupa and Aldo98229 like this.
  15. May 6, 2019 at 5:37 AM
    Aldo98229
    Aldo
    ^^^ this too.
    A buddy of mine has had this happen with Pro Comp ATs —which I believe are rebranded Cooper tires.
    But I wouldn’t expect a set of Michelins to do this.
  16. May 6, 2019 at 5:53 AM
    Cardsallday13
    agreed... thats part of the reason i went with them.
  17. May 6, 2019 at 5:58 AM
    Cardsallday13
    I talked to the store manager when i dropped it off this morning. They do not do a lug centric balance. don't have the adapters for it. strangely enough having a hard time finding one in the area that has it.
  18. May 6, 2019 at 6:34 AM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    "road force" balancing is only good if the shop actually knows how to use the machine.
    On that note though, if I was paying premium prices for truck tires they better not need road force balancing. I just put some cheap retread mud tires on and they ride smooth. They were balanced on a road force machine but not "road force" balanced. They suggested it but charge extra for the required dismounting procedure. I told them if I had problems I'd come back and get them road forced. They good though, and I really only got them for Wheeling anyway.
  19. May 6, 2019 at 6:39 AM
    TheGoat
    Justin
    Greenville, SC
    Also, how much weight did they use and what type of weights, clip on or stickys?
  20. May 6, 2019 at 6:40 AM
    Cardsallday13
    Stickys. I have it back at the shop. Don't remember how much weight but it wasn't a ton
