Vibration with new tires above 55mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cardsallday13, May 5, 2019.
  1. May 6, 2019 at 6:41 AM
    Cardsallday13
    Cardsallday13 [OP] Well-Known Member
    2017 DCSB TRD Sport 4x4
    the other weird part is that at the high speeds, the vibration would come and go. couple miles at a time...
  2. May 6, 2019 at 6:46 AM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    55mph is definitely a balance issue. That's like the standard speed you notice at. Got any friends with tacos you could swap wheels with to drive around the block? Issue is definitely weird since you've went to another shop to check it out
  3. May 6, 2019 at 6:54 AM
    Cardsallday13
    Yea. Idk. At this point I'm just going to let them swap the tires. They want to try a Yokohama geolander ht and see what happens
  4. May 6, 2019 at 6:59 AM
    Cardsallday13
    the dealer put weights in 3 different places on each wheel..
  5. May 6, 2019 at 7:02 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Road force balancers are a joke and do nothing more than any other machine, except display a lot of useless information that won't help. As the TheGoat stated the shop has to know how to use the machine.
    With that said I would approach it like this -
    - A vibration at 55mph is most typically caused by balancing. Assuming you had no vibration prior to the tire installation and that you bought Michelins, I would say that is most likely your cause. Michelins are the tires that are used to solve all other tire related ride quality issues. DO NOT let them swap you to Yokohamas.
    - The other causes of 55 mph vibrations are things like bent parts such as wheels, hubs, etc. You didn't have a vibration before, so unless something happened, it isn't likely.
    - Wheel alignment will NEVER cause your vibration.
    - A tire that has a hop on the balancer will have that same hop as it rolls. The tech needs to see how the tires roll on the balancer to determine if the problem is the tire or potentially the wheel. There are tricks to dealing with a tire that doesn't roll smooth. More lube, rotating the tire on the wheel, etc.
    - Toyota wheels are notoriously difficult to balance because of the large center hole.
    - The key to getting a perfect balance is the cone. Everything centers (literally) around this piece of equipment and is 99% the cause of ride problem with Toyota wheels. Take a look at this link - https://www.nytechsupply.com/coats/accy_cat_for_web/NEW_Coats_Balancing_Adapters.pdf Read the top section in yellow. I would be willing to bet all the money in my pocket that they are not using a cone with the correct taper and that is keeping your wheels from centering on the machine and thus causes in accurate balance. I would ask them if they have the "Toyota Cone" and if they don't, tell them they need to call their balancer rep. The bolt plate adapter previously mentioned is helpful, but not really necessary if they have the correct cone.
    TheGoat likes this.
  6. May 6, 2019 at 7:25 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    There is your problem. Find a shop or go to the dealership and ask the tire shop to pay for it.
  7. May 6, 2019 at 7:39 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You can also tell when its out of round tires because they often cause vibration that comes and goes - the tires get in sync and out if sync and make the vibration worse then less as you drive. Its often in a undulating pattern. Going through turns and around corners changes the pattern too.
    ridefreak likes this.
  8. May 6, 2019 at 7:42 AM
    TheGoat
    Justin
    Greenville, SC
    Who ever came up with the spin balancer is the snake oil sales man of the century, lol. All shops should have a bubble balancer to check their problems out on.
    On top of the spin balancer the "road force" addition is funny, "our tires are completely crap and so inconsistent you need a special tool to measure the uneven force it puts to the road and compensate for it."
    InfernoChalupa likes this.
  9. May 6, 2019 at 7:49 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Just had DT replace mine with a new set of Bridgestone Dueler Revo 3. 265/65/17. No issues to report. The Bridgestone's balanced way easier than the KO2's that came off, but DT has always gotten them done with no issues.
    Something seems pretty weird here.
    G.
  10. May 6, 2019 at 7:56 AM
    BBPSR54X4
    BBPSR54X4 Well-Known Member
    2017 SR5 DCSB 4x4
    Michelin Defender LTX MS 265/70/R16. Purchased and balanced at DT. Have taken them past 75 mph. No vibration.
    Garyji likes this.
  11. May 6, 2019 at 8:04 AM
    Cardsallday13
    So do I need to replace them or get them properly balanced
  12. May 6, 2019 at 8:40 AM
    Garyji
    Gary
    OP, the Michelin's are great tires. Seems strange that would be the problem. Especially after all you have tried.
    G.
  13. May 6, 2019 at 8:53 AM
    Cardsallday13
    Dropping off at the dealer now. They are stripping all the weights and doing it again.
    Garyji likes this.
  14. May 6, 2019 at 8:59 AM
    Sungod
    St Augustine
    Haaa, you must be my brother from another mother. I remember the Hunter rep when he first stopped by promoting the machine. We let them put a demo unit in and the guys avoided it because of the time it took to use the contraption. We were a pretty high volume shop doing 100+ tires a day and our tire techs were pretty good at what they did. I could see how a low volume shop that didn't have experience could potentially make money off the machine by charging more for a useless print out, but you are spot on with a bubble balancer. It might be slow and not as impressive as having all the Disney like nonsense, but the bubble is always in the center, never needs to be calibrated, and never needs a plug.
  15. May 6, 2019 at 9:02 AM
    #35
    Sungod
    St Augustine
    You need to find someone that has the proper equipment and knows how to balance Toyota wheels. That is more likely to be a high volume tire dealer and less likely to be a Toyota dealer.
    I would highly suggest watching them work. The first thing they should do is take off all the weights. If they used stick on weights, they should take a rag soaked in rubber buffer and remove all the old glue. They should then properly mount the wheel on the machine with the correct cone. Calibrate the machine for the tire size. Spin it by hand on the machine watching for any anomalies in the tire or wheel. If all is good, push the button and apply the weights at the correct locations. It is as simple as that, but EVERYTHING has to be done perfectly.
    Garyji likes this.
  16. May 6, 2019 at 9:14 AM
    #36
    Cardsallday13
    The one I have been working with is one of the highest volume tire dealers in the area and unfortunately have been unsuccessful.
  17. May 6, 2019 at 9:20 AM
    #37
    OnHartung'sRoad
    If the vibration is bad enough, as someone mentioned above, take them to a tire shop than can check and round them if you are keeping them. I had some Yoko high speed snow tires with the same issue- had them rounded and it worked.
  18. May 6, 2019 at 9:22 AM
    #38
    VaToy
    Parts Unknown
    Dealership should get you straight.
  19. May 6, 2019 at 9:26 AM
    #39
    VaToy
    Parts Unknown
    Old trick is to rotate the tire 180 degrees if the tire takes a lot.of weight.my Toyo open country at2 SL tires in 265/70/17 barely took any weight. I had a slight vibration and turned out I lost a weight. It was in the rear and could see where the weight was placed. They rebalanced it and all was good. I highly recommend Toyo open country at2 tires. They are known to last and have a 60k mile warranty.
    jmauvais likes this.
  20. May 6, 2019 at 9:33 AM
    #40
    VaToy
    Parts Unknown
    Michelin ownes BFG so there is another problem.
