Vibration with new tires above 55mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cardsallday13, May 5, 2019.
  1. Nov 18, 2023 at 8:34 AM
    #61
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Negative. Take all the weight off, and spin the tire on the wheel 180 degrees, then air it up and re- balance it. It's not a guarantee, but it does work in some cases.
    manderle[QUOTED] likes this.
  2. Nov 18, 2023 at 11:47 AM
    #62
    manderle
    manderle Taking my time.
    Michael
    Oregon, WI
    2019 Tacoma TRD OR
    3/2, on the level
    Ah, got it. Thank you. :cheers:
  3. Nov 20, 2023 at 6:04 AM
    #63
    Sungod
    Sungod Well-Known Member
    St Augustine
    Exactly as shelf said. Doing this reseats the tire on the wheel. Sometimes if they don't use enough lube, it doesn't seat properly. Moving it 180 degrees on the wheel would counteract if they happened to mount the high spot on the wheel with the high spot on the tire. This isn't as big of a deal these days as it was 30 years ago. Tolerances for both wheels and tires is much tighter now, but certainly doesn't hurt.
  4. Nov 20, 2023 at 6:07 AM
    #64
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Rebalance
    A wheel weight probably fell off
    manderle likes this.
  5. Nov 20, 2023 at 6:32 AM
    #65
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Put the front ones on the back see if it goes away you are less likely to feel a shake from balance then the front.
  6. Nov 20, 2023 at 7:21 AM
    #66
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    If u never had an alignment done before . It’s recommended when changing to new tires . Another thing u can do is road force balance the tires . When I installed my new tires I had vibrations . The alignment helped but was not completely gone . I had them road forced balance them that made a huge difference .i still had a little vibration . Once the tires wore in the vibration seems to resolve it self .
  7. Nov 20, 2023 at 9:57 AM
    #67
    Hpen123
    Hpen123 Active Member
    Harry Pence
    21' TRD OR Tacoma
    Wheels/ 275/70 R 17 AT's, OME Suspension, CBI front bumper, RCI Skids/sliders, prinsu rack.
    My BFG AT's run significantly better well above PSI on the door for some reason, cheap and maybe worth a shot. I run them around 44 PSI
  8. Nov 20, 2023 at 10:52 AM
    #68
    manderle
    Michael
    Oregon, WI
    2019 Tacoma TRD OR
    3/2, on the level
    Thanks, all. I have an appointment at Discount Tire tomorrow at 2PM. I'm hoping it will be resolved at that time. I think it's coming from the driver side front. On examination, the wheel weights are piled by the stem. I wonder if that is problematic at all? And/or perhaps the tire is out of round? Not sure, but it sure is annoying!
    Fingers crossed for an easy fix.
  9. Nov 20, 2023 at 2:51 PM
    #69
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    It should if they know how to use it, yes.
    The GSP9700 is not a magical balancer. It’s a diagnostic tool to determine if you have a wheel or tire issue and can optimize them to reduce vibration.
  10. Nov 21, 2023 at 1:13 PM
    #70
    manderle
    Michael
    Oregon, WI
    2019 Tacoma TRD OR
    3/2, on the level
    Just a follow-up, Discount Tire found that I was missing 4 ounces of weight on the driver side rear wheel, fixed free of charge. Hoping that fixes my vibes. We will see on the ride home tonight.
    Best,
    Michael
