Vibration with truck in neutral at 45-50 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheTaco09, Dec 1, 2022.
  1. Dec 1, 2022 at 7:55 AM
    TheTaco09
    TheTaco09 [OP] Well-Known Member
    2009 toyota tacoma i4 5spdm
    Urd short shifter Tss wheels
    When driving, once I reach 45 miles an hour my truck will start to vibrate badly. Like the entire cabin of the truck is being shot into space and is about to fall apart, but as soon as I reach 50 miles an hour, or slightly thereafter, it will stop and I will have a smooth ride until I have to decelerate back through that speed range. Any ideas as to what might be causing this phenomenon?
    This also happens with truck in gear too but to a slightly lesser degree.
  2. Dec 1, 2022 at 1:24 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Wheel balancing is the easiest place to start. Does it feel like it projecting through the steering wheel? Is so, could be front wheels.
    QuadDog likes this.
  3. Dec 1, 2022 at 1:28 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Automatic or manual? Automatics can have this when it locks up into overdrive gear around 45mph. Not saying that's your answer but something to consider. Maybe time for a fluid flush/change and new trans filter.
    Or it could be tire balancing, something in the driveline, etc etc. Vibrations are tricky sometimes. Good luck!
  4. Dec 1, 2022 at 4:53 PM
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    Consider driveshaft pinion angle if any lift or sagging rear
  5. Dec 8, 2022 at 3:46 PM
    TheTaco09
    It is a manual, in neutral and under power it will vibrate but only 45-50 mph
