Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phuket, Dec 11, 2011.
  1. Dec 11, 2011 at 1:22 PM
    Phuket
    Phuket [OP] Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    I have a 2003 dcab with a 3" lift and a 2" lift in the rear. At 50-60 mph I have bad vibrations. I've searched and believe i've narrowed it down to a bad driveshaft angle and a bit of axle wrap. But what do I do about it?
    here's a vid of the axle wrap:
    http://www.youtube.com/watch?v=l8ZeAMwCgZw&feature=youtu.be
    its not a lot but if you watch closely you'll see it.
  2. Dec 11, 2011 at 1:31 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Maybe carrier bearing? Shouldn't really be the axle wrap, especially on normal roads.. but meh. Have you checked to make sure the ubolts are tight?
  3. Dec 11, 2011 at 1:34 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    I have not. I will check on that. idk if this has anything to do with the vibes but i can move the drive shaft around inside of the bracket.
  4. Dec 11, 2011 at 2:11 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Have you replaced the carrier bearing,and/or put in a bearing drop?
    With the vibes at higher speeds-- are the tires new?
    Usually lower speed vibes have been linked to carrier bearing--less tha 45mph.
    Are the vibes "under foot" or to the rear of the truck. Sometimes it is difficult to determine where they are orginating.
    I went thru all the driveshaft BS- Finally put it on a lift--FRONT wheel bearing is worn-not time to replace YET.
    Mechanic said"Wait till i get worse.
    Symptoms--during cooler weather-below 40F--vibes at different speeds below 45mph.
    After "warm up" the vib goes away--He reported that the bearing is warming up and that the colder tires transmitt the vibes TOO.
    Best bet--put it on a lift--see exactly where is coming from.
    Take the mech a cup of coffee and a donut--he will probably do it for FREE!!
  5. Dec 11, 2011 at 3:07 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    the tires are new, they have approx 2k on em. i checked the bolts that i thought were necessary to the drive shaft and axle and all bolts are tight. I'm contacting a friend who professionally installs lifts to see what he says about it.
  6. Dec 11, 2011 at 3:16 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Check the EASY stuff FIRST--first thing that I thought of was TIRE balance.
    Putting it on the lift is your best bet--you can isolate the area where it is originating.
    GOOD LUCK.
    Remember coffee and donuts!!!!
    And a THANK-YOU.
  7. Dec 11, 2011 at 11:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Where do you feel the vibe? Steering wheel? Or floorboard/seats?
    Didn't see anything in the vid that seemed out of the norm. The 3rd member flexing up and down is not excessive.
  8. Dec 12, 2011 at 5:48 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    another vote for the carrier bearing. ....get up under there and give the driveshaft a good shake around the bearing. ..if it sounds crunchy, it's bad.
  9. Dec 12, 2011 at 8:22 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You probably have a little axle wrap (most do without upgrades to springs)
    but you can rule it out as far as vibrations at 50-60mph. you might want to drop your carrier an inch if you can rule out the easy stuff(tires.tire pressure, etc;)
  10. Dec 12, 2011 at 1:24 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    Get the tires rebalanced, most places will do it for free if you just got them installed. Tire shops seriously mess up balancing very often. If nothing else at least you will be able to rule it out. Might also try to get them road force balanced if you can. Some tires are probably more susceptible to this type of imbalance than others.
  11. Dec 12, 2011 at 5:57 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
  12. Dec 12, 2011 at 8:26 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    ^ I bought one of those from streetacos and it cleared my vibration right up. Cool video by the way...
  13. Dec 12, 2011 at 9:21 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    If you feel it in the steering wheel its tires/brakes, etc.. related.
    If you feel it in the body/seats its either u-joints, carrier bearing, or driveline angle.
    I had a bad vibe between 45-50mph and it was the two replaceable u-joints on the driveshaft. Replaced them and the carrier bearing, and it went away. (carrier bearing had some sag/play)
