vibration
Discussion in 'Technical Chat' started by tacoma44x44, Jan 22, 2009.
  1. Jan 22, 2009 at 4:54 PM
    tacoma44x44
    tacoma44x44 [OP] Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    im getting a small vibration in my truck when i come to a stop but goes away once i start rolling again. If im stopped and pop it into neutral it also stops. Just started doing this today. Has anyone else had this problem?
    thanks
  2. Jan 22, 2009 at 4:54 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Do you have a lift on your truck?
  3. Jan 22, 2009 at 5:06 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    no lift everythings stock
  4. Jan 22, 2009 at 5:21 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    hmm... that's a hard one for me to talk about as I don't have any experience with that on a stock truck. I'm sure somebody will chime in here. If it's terribly annoying, try the dealer, assuming you're still in warranty.
  5. Jan 23, 2009 at 12:45 PM
    josh3972000
    josh3972000 Well-Known Member
    kentucky
    02 dbl cab TRD
    Is it a vibration, or is it the low idle of the truck in gear which makes it seem like a vibration. Because when the truck is put in N the RPM will increase and in turn will smooth the "vibration"
