Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Birdman3, May 4, 2013.
  1. May 5, 2013 at 8:54 PM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    What bugs me more is the center console lid squeaks and the passenger headrest clunks over small bumps when someone isn't sitting there! Oh yeah and no intermittant wipers!!!!!!!!!!!!
  2. May 8, 2013 at 7:24 AM
    SteveT
    SteveT Well-Known Member
    Clarksville TN
    4x4/TRD
    bought mine used and got the same thing. initially thought it might be the brakes and rotors (which i need to replace anyway) but after finding a small puddle under the right front strut i am very sure mine is caused from that.
  3. May 8, 2013 at 10:45 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Mine has new rack bushings, ball joints and tie rod ends are good, new tires, fairly new bilstein shocks and struts. My mechanic says carrier bearing is good but thinks it is driveshaft. All joints are greased. IDK?
  4. May 23, 2013 at 6:44 PM
    budget76
    budget76 Active Member
    New Jersey
    98 xt-cab 4x4 4cl/2.7 stock man
    soon want dual lockers Picture was my 85 dual arb great
    98 4cyl 4wd manual 5speed - I have the same problem at 37-58mph. Just installed new michelins and still a problem. Will run engine on stands tomorrow and see if standing still it makes the vibration while on jack stands. May test with front and then rear drive shaft off to reduce shaft from the equation. Happens only under torque. Acell and decell. If I put my foot on clutch at 50mph, keep e ngine at 2000rpm, and coast, no vibration. Any thoughts appreciated.
  5. Jul 8, 2013 at 7:26 AM
    dapetik
    dapetik Well-Known Member
    David
    Barboursville, Va
    2015 TRD Sport
    Magic bedcover, sweet ass floormats, rocket boosters, warp drive
    Was this issue ever resolved? I have the same issue (vibes between 50-70mph).
  6. Jul 8, 2013 at 2:41 PM
    Matt Starr
    Matt Starr Active Member
    Lakewood, CO
    2003 3.4 5spd TRD Off Road
    6" Fabtech Lift
    Here's everything I know of that can cause vibration.
    -wheel & tire balance, bent rim, bubbles in tire sidewall
    -wheel not seated on hub properly, excessive slag build up on hub
    -wheel bearing (would start squealing first)
    -drive shaft center support, unbalanced drive shaft, bad u-joints
    -bad transmission mount (very common in R, W and A transmissions)
    -bad motor mount
    -bad steering rack bushings
    -bad control arm bushings
    -bad sway bar bushings. New ones can cause vibration too if they aren't seated properly.
    -broken cooling fan blade
    -bad differential mount bushings
    -internal transfer case bearings
    Thats all I can think of right now. And yes, I've experienced all of these, most of them in my Lexus SC400.
    Edit: Almost forgot. Shitty, cheap wheel spacers almost always cause vibration in my experience. Just FYI.
