Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by GreatChopps, Jul 20, 2014.
  1. Jul 20, 2014 at 4:40 PM
    GreatChopps
    GreatChopps [OP] Member
    01 Taco
    rear camera, DVD In-dash TV
    I have a vibration in my Taco I can not find the cause of, I have a new third member, new rear drive shaft, new tires balance 4 times at 2 different shops and new brakes. the vibration seems to be coming from the rear as the box shakes a lot when the vibration starts it does it mainly at higher speeds (60 plus) but also around 30 just not as violent. PLEASE HELP!!!
    This is a 2001 2.7 a/t 4x4 standard cab
  2. Jul 20, 2014 at 4:55 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Carrier bearing?
  3. Jul 20, 2014 at 4:58 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Sounds like a driveline issue, was the drive shaft balanced properly? Tires could be an issue, but not likely seeing they've been balanced 4 times. Start at the drive shaft, tighten bolts, make sure it's balanced properly.
    Vibes are no fun to diagnose but if they weren't there before you added all these things, at least you have an idea.
  4. Jul 20, 2014 at 5:07 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Have you checked your transmission mount. That rubber might be hard as a rock and not dampening. Loose or worn wheel bearings? Is new drive shaft balanced?
  5. Jul 21, 2014 at 5:52 AM
    GreatChopps
    01 Taco
    thank you for some other areas to look I am going to start with thr trans mount
  6. Jul 21, 2014 at 6:10 AM
    Andy.G
    Andy
    Virginia
    I take it the vibes were before the driveshaft replacement?
  7. Jun 8, 2015 at 7:36 AM
    Suspiciousmind
    Suspiciousmind Member
    Mark
    NC
    99 Taco 4x4 ext cab
    I had a similar vibration and decided it was my center support bearing. I ordered a replacement bearing (cheapo) and was going to install it this weekend.
    I chocked the front wheels, jacked up the rear under the diff, put it in neutral, then crawled under. I started rotating the drive shaft and looking for backlash and it became obvious that my universal at the diff was not tight. Went to NAPA and bought a new spider kit and rebuilt it and all's well now. One of the bearings wasn't getting grease and probably never had. It was completely dry and the bearings were dust.
    Anyway, all I'm saying is I couldn't diagnose this until I got the rear wheels off the ground.....everything felt tight.
  8. Jun 15, 2015 at 8:47 PM
    GreatChopps
    01 Taco
    I have a couple more things to Change, then I say F it and just live with it, next changes are the rubber transmission mount then the bushings on the steering. If not than in a few more years new Taco for Daily driver and this ones gets overhauled
  9. Aug 3, 2022 at 2:29 PM
    GreatChopps
    01 Taco
    Issue ended up being a bad Rim.
    Currygoat likes this.
  10. Aug 3, 2022 at 3:16 PM
    alexh
    alexh Well-Known Member
    1998 TRD
    I ws going to say this but you had tires balanced ( I had this once and it shook the box like you described).
    My last tire purchase the shop said I had a bent rim but they were able to compensate with the balance so I'm guessing sometimes they don't even tell the customer?
  11. Aug 3, 2022 at 5:11 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Damn 7 years later. Did you just find this out? How did you determine it was the rim? I'm also trying to figure out where my vibration is coming from. Annoying.
  12. Aug 3, 2022 at 5:20 PM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    At least he followed up LOLOL
  13. Aug 3, 2022 at 5:31 PM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
  14. Aug 3, 2022 at 7:13 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    What garbage shop did you go to that couldn't see that kind of run-out right off the machine?
  15. Aug 3, 2022 at 7:32 PM
    ztwatson
    Milwaukee, WI
    Absolute legend coming in 7 years later.
    ArizonaBrian[QUOTED] likes this.
