Vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jso223, Mar 10, 2016.
  1. Mar 10, 2016 at 12:02 AM
    jso223
    jso223 [OP] Active Member
    I have a 2011 TRD sport. I have had 2 wheel bearings put in on the left side and I still have a vibration in the truck it is not in the steering wheel it feels like it's coming from the back of it. Any suggestions on what the problem may be would be greatly appreciated.
  2. Mar 10, 2016 at 4:55 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Does it vibrate when accelerating and quit when you get off the gas? U Joints
    Or
    Does it vibrate all the time either accelerating or coasting? Tire balance.
  3. Mar 10, 2016 at 11:35 AM
    jso223
    It usually does it when I let off the gas. I just had the tires road force balanced yesterday.
  4. Mar 10, 2016 at 3:11 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Aftermarket wheels? If so are they hub or lug centric?
    The Tacoma is Hub Centric. If you have lug centric wheels you will need hub adapter rings.
  5. Mar 10, 2016 at 5:39 PM
    jso223
    Everything on the truck is factory for a TRD Sport. I think I might have heard the wheel bearing roar on my way to work today in a turn. Is it normal for my wheel bearings to be going out at 100,000?
  6. Mar 10, 2016 at 7:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I wouldn't say common, but it does happen.
  7. Mar 11, 2016 at 10:12 AM
    jso223
    I took the truck to the dealership and the wheel bearings were good. They also checked the driveline components and they where good also. When I got home I took a look at the tires and my tires with 5000 miles on them had started to chop up.
  8. Mar 12, 2016 at 6:33 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Alignment and Tire balance...
