Vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dude500, Feb 8, 2021.
  1. Feb 8, 2021 at 11:17 PM
    Dude500
    Dude500 [OP] New Member
    2021 4+4 sport Tacoma
    2 inch leveling kit
    Hello! Was hoping someone here could shed some light on this for me. Got a new Tacoma here and put a leveling kit. 2 inch Simple little leveling kit! And bammmm! Vibration. Thought it was the tires, and nope. I rotated and balanced. Same thing happens Around 45 like everyone else. Do I need to take it off? Is there a lift that I can do so that it won’t make a vibration? 2000 miles on it! Hummm! Little disappointed in this truck now.
  2. Feb 8, 2021 at 11:23 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    What leveling kit?
    Spacer lifts stress your suspension and can increase NVH.
    Does the vibe go away when in 4WD?
    If so look into the ECGS needle bearing bushing replacement.
    If not check your driveshaft angles you may need a carrier drop. (Not a diff drop.)
    sbx22 and 71tattooguy like this.
