Vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACST1, Apr 9, 2022.
  1. Apr 9, 2022 at 9:56 AM
    TACST1
    TACST1 [OP] Member
    Joe
    2010 Tacoma TRD
    Hood Decal
    Have a 2010 tacoma TRD Accees Cab with 188,000 miles. Have a slight vibration between 40 and 44 mph. More noticeable pulling a slight grade. Replaced carrier bearing. Still a vibration. I went from 16 inch rims to 17 inch rims.
    Any suggestions.
    Joe
  2. Apr 9, 2022 at 9:58 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Have the rear leaf springs been replaced under recall, yet?
  3. Apr 9, 2022 at 10:01 AM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    There are a multitude of threads on the subject of vibrations.
    The easiest problems to mention:
    Road-Force balance the tires
    Check alignment - probably the align/balance with the pulling problem you're having
    Grease your drive-shaft fittings regularly, ~5k miles
    Get on the highway and engage 4HI, if there are no vibrations, could be the needle-bearing in the transfer case. There is a clam-shell fix by ECGS for this.
    007fodo likes this.
  4. Apr 9, 2022 at 10:03 AM
    TACST1
    TACST1 [OP] Member
    Joe
    2010 Tacoma TRD
    Hood Decal
    Thank you
  5. Apr 9, 2022 at 11:43 AM
    motorhead310
    motorhead310 Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
    I had a low rpm vibration. A full transmission flush at the dealer fixed it. I think it was only 200 bucks. That should last me another 200k miles.
