Vibrations after lift.
Discussion in 'Suspension' started by Oowen, Oct 8, 2012.
  1. Oct 8, 2012 at 7:42 PM
    Oowen
    Oowen [OP] Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    I recently lifted my 09 double cab 5in in the rear with Alcan rear leafs,and lifted the front 3in fox 2.5's up front with camburg's ball joint uca. Nothing was dne to the driveline. After the lift I noticed there were some harmonics at 55 to 60 mph. I suspect it is the driveline. It was greased which seemed to make it better. Need some input before messing with it. Has this happened to anybody else?
    Thanks
    Edit: the truck has almost 60,000 miles
  2. Oct 8, 2012 at 7:44 PM
    Large
    Large Red
    This has happened to probably 7 out of 10 lifted trucks here. There are several solutions including axle shims, CB drops, and a 1 piece drive shaft. Good luck bud.
  3. Oct 8, 2012 at 7:45 PM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    So prior to adding this specific lift the truck was at stock height?
  4. Oct 8, 2012 at 7:48 PM
    Oowen
    Owen
    Reno, NV
    '22 Cummins
    Yes, but the rear was sagging 2in
  5. Oct 8, 2012 at 7:48 PM
    TeamLombardo
    Tony
    El Paso
    Ah yes, Large.
    I will have to concur with Large's statement
  6. Oct 8, 2012 at 7:48 PM
    Oowen
    Owen
    Reno, NV
    '22 Cummins
    Where can I get cb drop kits? Or a one piece drive shaft?
  7. Oct 8, 2012 at 7:49 PM
    TeamLombardo
    Tony
    El Paso
    I would recommend doing one thing at a time. Do a CB drop first (easy and cheap), then try some shims for the leafs. Toytec has 2 diff ones you can go with.
  8. Oct 8, 2012 at 7:50 PM
    TeamLombardo
    Tony
    El Paso
    Toytec has CB drop kit and shims as well. Use discount code 112710 if you order from them.
  9. Oct 8, 2012 at 7:51 PM
    Large
    Large Red
    CB drops come in different shapes and sizes. ToyTec sells some, I stacked 2 together and almost completely rid my vibes before switching to a 1 piece shaft. I also bought one from StreetTacos, it's a custom piece of CNC cut & bent steel but the wait is kind of long to get one.
  10. Oct 8, 2012 at 7:52 PM
    Large
    Large Red
    If you are near a loose gravel road you could make sure it's the axle wrap giving the vibes by removing the shaft, putting it in 4H (assuming you are 4wd) and drive around.
  11. Oct 8, 2012 at 7:52 PM
    TeamLombardo
    Tony
    El Paso
  12. Oct 8, 2012 at 7:52 PM
    Oowen
    Owen
    Reno, NV
    '22 Cummins
    Ok so what would be stronger quicker and all around better.
  13. Oct 8, 2012 at 7:53 PM
    TeamLombardo
    Tony
    El Paso
    CB drop kit
  14. Oct 8, 2012 at 7:55 PM
    TeamLombardo
    Tony
    El Paso
    Whoa! Stronger=Driveshaft; Quicker=shims/CB drop; All around Better=Depends on which one fixes the problem first
  15. Oct 8, 2012 at 7:56 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Get yerself a woody
  16. Oct 8, 2012 at 7:56 PM
    TeamLombardo
    Tony
    El Paso
    Start small, then work your way up. That's my recommendation. I have both the CB drop and shims and i have an ever so light shutter at like 10mph. That's it!
  17. Oct 8, 2012 at 7:57 PM
    TeamLombardo
    Tony
    El Paso
    LOL. And then go find yourself and AWESOME surf?
  18. Oct 8, 2012 at 8:00 PM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Tom Woods, "woodie" driveshaft.
    Honestly best bet is to do what Xavier recommends, start cheap and easy, you might be happy with just an improvement cuz you may never eliminate all vibes. CB drop takes about 5 mins to install, start there. 1 piece shafts are nice but pricey and you lose some clearance
  19. Oct 8, 2012 at 8:03 PM
    TeamLombardo
    Tony
    El Paso
    :smack: I'm a tard! I thought you meant get rid of the Taco for a Woody.
  20. Oct 8, 2012 at 8:05 PM
    Oowen
    Owen
    Reno, NV
    '22 Cummins
    Ok thanks for all the information. Looks like I am going to try the drop kit first.
