Vibrations at 40-50mph. Wheel bearings?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pahaf, Jan 17, 2021.
  1. Jan 19, 2021 at 7:45 PM
    pahaf
    pahaf [OP] Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    im not sure how they were balanced, but it was done at American tire.
    steering wheel.
    i checked it all and it does seem to be tight.
    seems like the 4th gen 4Runners have this issue as well.
    might do a drain and fill tommo and see if it helps.
  2. Jan 24, 2021 at 6:43 PM
    pahaf
    paul
    NorCal
    so far i did.
    full tranny flush with the shudder fix. didnt help
    turning on 4wd didnt make it go away
    got all tires balanced and rotated. didnt help
    checked for play and noise in the wheel bearings. seem all good
    and today i removed the driveshaft and drove in 4wd.....no vibration.
    so i read on a thread here to flip the carrier bearing, didnt help.
    then to put a spacer on the carrier bearing. didnt help either.
    so my driveshaft could be bad or a failing u joint.
    will call tommo to a driveshaft shop and see what they can do for me.
  3. Jan 24, 2021 at 7:19 PM
    Hyperbarics
    Hyperbarics Commercial Diver & Taco Driver
    Savannah, GA
    2013 DCSB - Nautical Blue Supremacist
    Had a similar issue recently in my girlfriend’s Subaru OB.. the driveshaft flex coupling was damaged. If you’ve ruled out wheels and the front end, maybe a culprit or something similar.
    EDIT-
    Missed that post... But sounds about right. Good luck!
  4. Jan 25, 2021 at 8:56 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Since it's lifted, did you check the pinion angle?
    T-yoda likes this.
  5. Jan 25, 2021 at 1:37 PM
    pahaf
    paul
    NorCal
    I did not. I need to do that. Planning to do it sometime this week
