VIBRATIONS FIXED!!! explanation and pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scottj, Nov 15, 2010.
  1. Nov 15, 2010 at 6:26 PM
    scottj
    scottj [OP] Well-Known Member
    York, PA
    12 DCSB TRD sport OME
    The 3/4 inch and 1 inch spacers included with the Pro Comp 6 inch kit did nothing but move vibrations to different mph's for me and never elliminated take off vibs completely. A call to Pro Comp suggested this.
    THE FIX - Pro Comp part# EXP-57091B. Transmission Crossmember/Carrier Bearing Drop. Purchased for $169 from Summit Racing. It has since gone up to $236.95.
    http://www.summitracing.com/parts/EXP-57091B/
    This part drops the rear of the transmission and allows for a larger carrier bearing drop. The carrier bearing is dropped 3 inches.
    2007 Tacoma 4X4 TRD Sport
    Pro Comp Stage 1 six inch lift
    LR UCA's
    18x9 XD Monsters
    295/70/18 Nitto Trail Grapplers
    The part in the upper right is for 2WD applications only. I did not use it.
    Pro Comp supplied the wrong bolts for bolting the carrier bearing to the drop. Had to make a trip to the hardware store.
    THIS PART ELLIMINATED ALL VIBRATIONS!!! I tested from numerous dead stops to 80mph. I couldn't be happier:)
  2. Nov 15, 2010 at 7:36 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    2011 DC 4X4 TRD Sport
    RCD Lift, Custon Alcan Leafs, Ballistic Jesters, Duratracs 285/70/17,Fold-a-Cover Elite G4 Tonneau, Black Grill Emblem, Sock Monkey Yeti Decals, Tundra 4x4 emblem sprayed black, Debadged, LED interior, Xenon Depot 6000K HID Headlights, Xenon Depot 3000k Fogs with Lamin-X Coating, Borla Exhaust - Chopped, Weathertecs, Custom Katzkin Leather TRD Interior.
    Did you have a take off shudder before or some other vibe?
  3. Nov 15, 2010 at 7:42 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    IMO that is a horrible idea. That puts a different angle on the motor, which can mess alot of things up. The first thing would be your fan hitting the shroud. And its probably not very good for the motor mounts.
    Glad to see you haven't had any problems yet.
  4. Nov 15, 2010 at 11:50 PM
    scottj
    York, PA
    sandjunkie, yes take off vibs. truck feels more solid than ever now. If you are worried about stress on other items, you probably wouldn't lift your truck to begin with. The tranny probably only came down an inch and a half to help get everything in line.
  5. Nov 16, 2010 at 3:49 AM
    DontPanic
    DontPanic Well-Known Member
    VA
    by the time one invests time, money, and energy in the various drops I imagine a one piece double cardan drive shaft might begin to be in reach, no?
  6. Nov 16, 2010 at 11:08 AM
    sandjunkie
    Aaron
    OC
    Lift blocks are already tapered. I have experimented with different CB drops between 0-1 inch. I don't have vibes anywhere but a take off situation slight shudder. I don't know if it is the carrier bearing/driveline angle or leafspring axle wrap.
    Any suggestions?
  7. Nov 16, 2010 at 4:35 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    x2... it may be okay, for now, but could lead to problems further down the road. kinda like spacer lifts, everything seems all fine and dandy at first, but sooner or later you end up replacing ball joints, shocks, uca's etc...
  8. Nov 18, 2010 at 12:39 PM
    scottj
    York, PA
    All I know is I like the truck again. Vibrations were driving me crazy. Now if only I could make my truck a double cab long bed.
  9. Nov 19, 2010 at 2:47 PM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    To fix mine i just put an all pro pack with a set of 3* shims in the rear.
  10. Nov 19, 2010 at 3:01 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    an 1 1/2 down:eek:.thats alot till it gets to the front of the motor.keep an eye on those motor mounts.
