Vibrations in the steering wheel from 60-65 mph...any ideas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaGus, Aug 21, 2010.
  1. Aug 21, 2010 at 9:28 AM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i just got new wheels and tires, obviously had them balanced and had an alignment done on tuesday and took a mini road trip this weekend and when i get to about 60mph whether i'm accelerating decelerating or just coasting, i get vibrations in the steering wheel but the truck seems to be riding fine and not bumpy its just the steering wheel. any ideas?
  2. Aug 21, 2010 at 9:33 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    The balance is still a little off. Exactly what happened to my truck. Take it back and ask them to check the machine calibration and rebalance.
  3. Aug 21, 2010 at 9:36 AM
    TacomaGus
    Gus
    Morgantown, WV
    well i won't really be able to go back to them since their not open on weekends and i'm at college now so the only time i can go is weekends so i'll have to go to someone else but i'm glad to know its just the balancing
  4. Aug 21, 2010 at 7:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I agree with ISU that it is likely a wheel balance issue. One thing you can do is to move the front wheels to the back and see if the vibs change. If they do, you've pretty much narrowed down the culprit. A rear wheel out of balance you will generally feel in your seat.
    However, it they don't change, there might be some other factors involved.
    When I first lifted mine, I had similar vibs that were limited to high speeds. They showed up between 55-65 mph. Turned out I had just a little bit of axle boot rub. I could see and feel where one finn on each 'inside' boot was touching the one next to it. Just barely though. My solution was installing the diff drop kit which fixed it.
  5. Aug 21, 2010 at 8:11 PM
    already7
    already7 Member
    Allen
    North Little Rock, AR.
    03 4x4 TRD SR5
    Definitely still a little out of balance. I had the same problem with mine. At about 63 it would start to pick up a vibration. Had to have them rebalanced with only 3k miles on them.
  6. Aug 22, 2010 at 7:29 PM
    TacomaGus
    Gus
    Morgantown, WV
    mine only have about 500 miles and i'm having this problem
  7. Aug 22, 2010 at 8:12 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    There have ben many threads about steering wheel shaking and vibration at around 45MPH to 70 MPH. I myself have had this problem.For some time. I have had my tires balanced many of times with no success. Well I am here to tell you guys that it is a diffinate tire balance issue. I just had my tires rebalanced from another tire shop.This guy took his time would not give up until it was right. It took him about an hour and a half. After driving it around for a day. It is as smoth as glass. No more shaking of the steering wheel. Man that is a great feeling. I am running BFGs AT. 31x10.50R15.[​IMG]
