Vibrations!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by xJRich5, Dec 6, 2011.
  1. Dec 6, 2011 at 4:27 PM
    xJRich5
    xJRich5 [OP] Well-Known Member
    Josh
    Albany, OR
    '99 Tacoma Limited 3.4L V6 5-Speed
    Ghetto ass 2" spacer lift. Black grill and bumpers. Too tiny 31's.
    So I recently purchased bilstein 5100's front and rear, Eibach coils, and a Toytec AAL. I installed all of that along with a diff drop.
    Now I have a very annoying vibration. It mainly happens in second gear around 2000-3000 rpms, then in third gear around 2000.
    It is driving me insane. How do I fix this? Please help.
  2. Dec 6, 2011 at 5:53 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Perhaps with a carrier bearing drop. Probably is driveshaft vib. Did you get the truck aligned after the lift?
  3. Dec 6, 2011 at 6:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    this & did you drop driveshaft for any reason ? (you never know)
  4. Dec 6, 2011 at 11:44 PM
    xJRich5
    Josh
    Albany, OR
    I did get an alignment, they said it turned out good, but without new UCA's it won't be perfect.
    What do you mean by dropped driveshaft? I fucked up when I went to install my rear and while raising my springs, I accidentally let my axle roll forward and down, which exposed atleast 6 inches of my driveshaft. If that's what you mean by that, ya I did it, like a dumbass.
    So I am looking into the drop kit, and I'm gonna lube my driveshaft, won't hurt anyway.
  5. Dec 6, 2011 at 11:53 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    if the driveshaft is ok, look into your nuts on the ubolts...
    since you broke them open to install the AAL, after your first 100 to 500 miles, it helps to re-torque the nuts to make sure they haven't vibrated loose... if the rear suspension is loose, and your axle is shifting, it could also be causing the driveshaft to vibrate and impact the carrier bearing...
    i've seen someone lose a ubolt nut while wheeling on a freshly installed leaf pack...
  6. Dec 7, 2011 at 12:06 AM
    xJRich5
    Josh
    Albany, OR
    That's good to know, it's been about 40 miles, I just retorqued everything I messed with on the install, no help.
    But I did just purchase a BEEFED carrier bearing drop kit, hope it works!
  7. Dec 7, 2011 at 12:08 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    The only reason I mentioned that (shaft removal) is because its easy to forget to mark the flanges before removal thus throwing off balance which can cause driveline vibrations, exposing the shaft isn't a big deal...
  8. Dec 7, 2011 at 2:04 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    let me know if the carrierr bearing drop works. I've got vibes too, and I just did my lift, and replaced the carrier bearing too.
  9. Dec 7, 2011 at 3:03 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    As I recall after I rebuilt my leafs I did have a little vibration until I put some 1" spacers & dropped the carrier, after that no vibes...;)
