Victory4x4 NMO Antenna Bracket
Discussion in 'Technical Chat' started by Athena32, Mar 7, 2022.
  1. Mar 7, 2022 at 8:42 PM
    Athena32
    Athena32 [OP] Systems Engineer
    Nate
    Colorado
    2021 Tacoma Super White DCSB OR 6MT
    Evening folks. Has anyone painted, or recommends painting, the Victory4x4 NMO bracket? It looks to be raw aluminum and I have some concerns about it rusting over time. My thought process is that as long as you sand off the interior of the holes, it still makes good contact with the body thus keeping the vehicle part of the ground plane.
    Any comments or thoughts?
  2. Mar 9, 2022 at 4:15 AM
    adhumston
    adhumston Well-Known Member
    If it's aluminum, it won't rust
    fatfurious2, Bivouac, HisDad and 2 others like this.
  3. Mar 15, 2022 at 7:40 PM
    RDW59565
    RDW59565 Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    I've got one....but not installed yet. Still waiting on a truck. I will be painting the top and sides of the bracket that are exposed, but will leave the bottom unpainted so that the bottom of the NMO mount can get good contact and continuity. I will be putting PVC tape on the top where it contacts the hood. I don't want to have aluminum in contact with the steel on the underside of the hood. I intend to drill and tap the bracket so I can connect a ground wire directly to the bracket.
  4. Mar 15, 2022 at 8:08 PM
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    I just installed mine. I'm going to leave them as is so they get a good ground.
