Video - Play in my drive shaft..is this normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruce1271, Nov 23, 2009.
  1. Nov 23, 2009 at 4:42 PM
    bruce1271
    bruce1271 [OP] Well-Known Member
    http://www.youtube.com/watch?v=AJZgEDTt7L4
    When I put the truck in gear and reverse then put it in drive, then reverse again, the drive shaft turns a little. Is this normal? I am trying to diagnose a start from 1-10mph issue where it feels like I am riding over shallow grooved "rumble strips". Kind of like a vibration, but it depends on how fast I am going. Disappears (or I cant feel it)at about 10mph.
    Thanks
  2. Nov 23, 2009 at 7:39 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i have a 09 dc 4x4 sport,feels the same way as you discribe.
  3. Nov 23, 2009 at 8:57 PM
    bruce1271
    I have 91,000 miles on my 05 and This just started a few months ago. Bought new tires and still have the same problem. I dont care about it as long as it doesnt prelude something major that I am ignoring and can fix now.
  4. Nov 24, 2009 at 4:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The driveline will have some play in it (as you see in the video).
    The driveshaft & pinion will pivot as you apply the gas/torque and will also pivot as your suspension moves up/down. Also, the carrier bearing (center) will also move. The driveline is not supposed to be rigid or else things would break easily. That's a cool video ....but everything looks normal to me.
    I have an 07 and I also have the same rumble from time to time normallyl just as I start off under 5-10mph and usually after a sharp turn out of my driveway. I'm thinking it might be the mechanical LSD...but I really don't know.
    Does yours do it all the time? If you're still under warrantee, have you taken it to the dealer? Are you a new owner? Did this just start happening? When was the last time you did any diff service (oil changes)? Lubricated your u-joints & driveline?
  5. Nov 24, 2009 at 5:52 AM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    Lubricating the 5 zerks on your U joints makes a WORLD of difference!! Quited down my '06 after I bought it with 40k miles.
  6. Nov 24, 2009 at 6:37 AM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    2WD or 4x4?
  7. Nov 24, 2009 at 7:35 AM
    Warren Thompson
    Warren
    Elko, Nevada
    4X4, but the rear driveline is what makes the difference.
  8. Nov 24, 2009 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No grease zerks on the Prerunners. :(
  9. Nov 30, 2009 at 12:54 PM
    bruce1271
    Just to update this thread for my solution...I had a bad u joint near the transmission(needles were a rusty dust pile). Replaced all three since the shaft was off and the bumpyness is completely gone.
  10. Nov 30, 2009 at 1:37 PM
    Warren Thompson
    Warren
    Elko, Nevada
    Glad to hear:). This is what happens when the u joints are not properly greased!! Let this be a lesson to us all!! If the roller bearings were rusted, then they had no lubrication.
    I am assuming, of course, the bruce1271 did not have a prerunner...
  11. Nov 30, 2009 at 1:51 PM
    bruce1271
    Actually, I have a pre-runner and a sealed U Joint. So, no way to lube those.
    I am dumbfounded that the joint failed with 90k miles of highway/city driving. Oh well. I have bruised knees and a sore lower back, but have gained knowledge in the process.
    I am going to get my transmission fluid changed tomorrow at the stealership. $155 for a flush. I asked about dropping the pan, but the service advisor says they flush 16Quarts of fluid through the system and that blows the filter clean. Not sure what to think about that.
  12. Nov 30, 2009 at 1:58 PM
    Warren Thompson
    Warren
    Elko, Nevada
    Experience comes with pain:D. Brused knees will heal, with the needed callousing:rolleyes:!!
    I can't understand why pre-runners do not have zerks IF they fail due to rust. The seal must have leaked or something. Glad your problem is solved with so much frustration. Good luck with your tranny flush.
