Video: terrible popping sound in 4wd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1776Taco, Jul 14, 2021.
  1. Jul 14, 2021 at 12:57 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Probably worth checking the hardware and putting a wrench on all of them. Had a friends truck make a similar popping sound and it was one of the bolts in the bottom that goes up through the slider and frame into one of the crossmembers. Was just barely loose but would make a pretty wicked pop sound flexing.
  2. Jul 14, 2021 at 1:03 PM
    kherron
    kherron Well-Known Member
    Kevin
    Folsom, CA
    2020 Tacoma TRD Pro
    Kinda sounds to me like a tire rubbing on something?
  3. Jul 14, 2021 at 1:07 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    CV axle pop. Or something rolling around in the bed or cab. Try to pinpoint if it's left or right side.
  4. Jul 14, 2021 at 1:09 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    You said it makes the noise in 2wd too, I wouldn’t think it would be the CV’s, or anything else in the front driveline if that was the case…
    I could be wrong
  5. Jul 14, 2021 at 1:12 PM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    If you have front pucks on top of the coil you can get binding when flexing. Makes the snap noise. Spring probs rubbing control arm. Pull the front wheels and look at springs and arms to see if there’s contact. Or a loose shock strut bolt.
  6. Jul 14, 2021 at 1:15 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    really just look for shiny rub marks
    Mark77 likes this.
  7. Jul 14, 2021 at 1:23 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    What about tire knob catching mud guard for example? Or something like that.. if it is under full flex and on an angle, if op has bigger tires it could be that…
  8. Jul 14, 2021 at 1:33 PM
    1776Taco
    1776Taco [OP] Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    It’s a metal to metal sound. Not a bad suggestion tho
  9. Jul 14, 2021 at 1:36 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Put the camera under the truck by the rear end and see what it sounds like, Then put the camera under the truck by the Trans and see what that sounds like.
    That will help you get closer to the source of the noise
    Mark77 likes this.
  10. Jul 14, 2021 at 1:38 PM
    eon_blue
    Azusa, CA
    I had a popping noise like that when the truck flexed over bumps that turned out to be one of my front leaf spring hangar/main eye bolts had worked loose. Could turn it by hand. Got lucky it didn't back out entirely.
    Made an awful racket too. I remember it being pretty obvious it was coming from the rear though.
    Anyway, another vote here to make sure nothing is loose esp with the suspension
  11. Jul 14, 2021 at 1:42 PM
    1776Taco
    2019 2.7 4x4 SR
    Some rub marks on upper control arm from tire. Don’t think that would cause this noise
  12. Jul 14, 2021 at 1:43 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    No, wouldn’t be surprised if you had a 2-3” lift on stock uppers to see some polished marks on the inside where it would contact the spring or marks on the spring itself.
  13. Jul 14, 2021 at 1:44 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    UCAs hitting something? Id mount a camera underneath and do that again. Various places.
  14. Jul 14, 2021 at 1:49 PM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    Sounds like you pissed off the locals and they're sending rounds your way.
    On a more serious note, are you able to get the truck into a position where it's making the sound then have someone go to each corner and rock the suspension? May help narrow it down to a suspension or mechanical issue.
  15. Jul 14, 2021 at 1:51 PM
    #35
    1776Taco
    2019 2.7 4x4 SR
    Just headstrong 1/4 inch spacers
  16. Jul 14, 2021 at 1:51 PM
    #36
    1776Taco
    2019 2.7 4x4 SR
    It really only does it when moving, or else I’d try. Getting really pissed off at the truck rn.
  17. Jul 14, 2021 at 1:53 PM
    #37
    1776Taco
    2019 2.7 4x4 SR
    Slight rub marks on uca from tire. Shouldn’t cause this noise
    Mark77[QUOTED] likes this.
  18. Jul 14, 2021 at 1:56 PM
    #38
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I had a popping sound from my transmission cross member where it bolted to the frame. I loosened the bolts, put pressure on the xmember with a jack, then tightened the hell out of the bolts to get the noise to go away.
    Also check that your pinch welds aren't hitting your sliders.
    Mark77, 1776Taco[OP] and eon_blue like this.
  19. Jul 14, 2021 at 1:59 PM
    #39
    eon_blue
    Azusa, CA
    That's a good point about the sliders since they were a recent install. If there wasn't enough of a gap left between them and the pinch weld, they'll hit and make a lot of noise.
  20. Jul 14, 2021 at 1:59 PM
    #40
    1776Taco
    2019 2.7 4x4 SR
    I checked the pinch welds with sliders. No contact
