vin question
Discussion in '4th Gen. Tacomas (2024+)' started by TacoRancher, Sep 8, 2024.
  1. Sep 8, 2024 at 12:30 PM
    TacoRancher
    TacoRancher [OP] Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    If my vin ends in 6262, but was built in August 2024, how is that possible? Wouldn’t we have over 100,000 by now or is there some other meaning to the final digits?
  2. Sep 8, 2024 at 12:36 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Every letter and number before the last 5 or 6 mean something like what country, plant, year, transmission type, cab type etc.....there are a ton of combination that can be had before you get to the actual production number.
    So it is possible to have your VIN since it is a trailhunter and not a lot of those have been built.
    2024 TACOMA VIN DECODER
    3TM = Toyota Mexico Baja Factory
    3TY = Toyota Mexico Guanajuato Factory
    J = XtraCab with GVWR below 6000 lbs
    K = Double Cab with GVWR below 6000 lbs
    L = Double Cab with GVWR above 6000 lbs
    B = 278 hp AT (SR5/TRD Sport/TRD Off Road/Limited)
    C/F = Hybrid (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited)
    D = 228 hp AT (SR 8AT)
    E = 270 hp MT (SR 6MT/TRD Sport 6MT)
    A = XtraCab
    5 = Double Cab
    F = 278 hp 2WD (SR5/Prerunner/TRD Sport)
    H = 228 hp 2WD (SR)
    J = 27x hp 4WD (SR 6MT/SR5/TRD Sport/TRD Off Road/Limited)
    K = 228 hp 4WD (SR 8AT)
    L = Hybrid 4WD (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited HV)
    N = Tacoma
    _ = Check Digit
    R = 2024 Model Year
    M = Toyota Motor Manufacturing de Baja California Plant
    T = Toyota Motor Manufacturing de Guanajuato Plant
    ______ = Serial Number
  3. Sep 8, 2024 at 12:43 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The last six digits are the vehicle specific serial number. Whether they are sequential for the year across all models, specific to type (SUV, sedan, truck, etc) or specific to model (Tacoma, Camry, etc) depends on the manufacturer. For instance, my '21 TRX was 321989 since Ram uses sequential numbers assigned across all trucks built and doesn't differentiate between models at all in the serial number range. My '22 Rivian was sequentially numbered by year and model so I know the truck was the 11,709th to be assigned a VIN.
