vin swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by ef5657, Nov 19, 2023.
  1. Nov 19, 2023 at 10:14 AM
    ef5657
    ef5657 [OP] Member
    2000 frame 1997 cab tacoma
    200 fram 1997 body
    I have a 1997 cab on a 2000 frame. The title reads oneVIN# but the OBD reader reads the 97 VIN#. Anyone know how to change a vin to read the title VIN?
    Appreciate any help I can get!
    cheers
  2. Nov 19, 2023 at 10:22 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I don't think 1st gens support a VIN write in the PCM but I would think you would want the VIN in the PCM to match the drivetrain so the scan tool can properly ID the vehicle.
    SH10151 likes this.
  3. Nov 19, 2023 at 10:23 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    The VIN follow the cab, swapping the frame will not change the vin on the cab or the ECU.
  4. Nov 19, 2023 at 10:23 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I am some what confused Just how does your OBD II system access the Vin ?
    Non of the Mix and Match I ever worked on were unable to do this.
    If it is able to do this was your Tacoma imported from outside the CONUS
  5. Nov 19, 2023 at 10:25 AM
    Bivouac
    ECM needs to match the power train like you stated.
  6. Nov 19, 2023 at 10:25 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The VIN is stored in the PCM, any scan tool with a VIN read function can read it.
    Newer vehicles have the VIN stored in multiple modules on the vehicle.
    Bivouac[QUOTED] likes this.
  7. Nov 19, 2023 at 10:27 AM
    Bivouac
    Your not talking your less then $50.00 tool are you
  8. Nov 19, 2023 at 10:28 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'm guessing he needs them to match to pass emissions, idk how one would get around that.
    We don't have to worry about that here.
  9. Nov 19, 2023 at 10:30 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Any one that supports OBDII mode $09 can pull the VIN.
  10. Nov 19, 2023 at 10:32 AM
    Bivouac
    Must be a state law I never had any problems.
    Passing Emissions here in Pa with the same set up different years.
  11. Nov 19, 2023 at 10:34 AM
    Bivouac
    Learn new things every day. Thanks for explaining.
  12. Nov 19, 2023 at 10:35 AM
    ef5657
    ef5657 [OP] Member
    200 fram 1997 body
    yes correct for emissions. idont need to pull the VIN I need to change it so it matches the title that was issued
  13. Nov 19, 2023 at 10:38 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think it depends on the state and how they do emissions reports.
    Im not sure exactly how it works but I'm pretty sure states like California and New York have to attach the vehicle scan report that contains the VIN and monitor status to the inspection report, if it doesn't match the title on the vehicle it won't pass.
  14. Nov 19, 2023 at 10:40 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'm not sure, 2nd gens support VIN write in the PCM with a proper scan tool but I'm not sure if 1st gens do.
  15. Nov 19, 2023 at 1:24 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Try the dealership maybe. It might only be able to be written 1 so you'd need a new ECU. You might call the DMV and explain. Usually, the vin on the title follows the cab vin, not the frame vin unless you cab swapped but then idk why you didn't keep the 2000 ecu.
  16. Nov 19, 2023 at 4:25 PM
    ef5657
    ef5657 [OP] Member
    200 fram 1997 body
    Oregon does it different. They issue a new reconstructed title with a completely new VIN. That's the problem VIN in the ECU is from the cab and I need it to match the new VIN given to it by the state of Oregon. Or it won't pass emissions. Becoming quite a pain it seems
  17. Nov 19, 2023 at 4:27 PM
    tacoman2001$
    Call the dmv and see if you can produce paperwork for the ecu vin if it'll pass. Pretty stupid setup though.
    Bivouac likes this.
  18. Nov 19, 2023 at 4:35 PM
    ef5657
    ef5657 [OP] Member
    200 fram 1997 body
    it passes.. the vin just doesn't vibe with the title so they fail it. So stupid! Go figure coming from a state government...HAHA
    Bivouac likes this.
  19. Nov 19, 2023 at 5:16 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    the ECMs on these trucks dont contain vin info. from what youre saying the vin on your title is to the frame, not the cab. in which case... you cannot legally swap the vin from the other cab to your cab.
    are they scanning the bar code on your cab before hook up?
  20. Nov 19, 2023 at 5:35 PM
    ef5657
    ef5657 [OP] Member
    200 fram 1997 body
    Nope there is no other VIN except the one stored in the ECU. THE STATE OF OREGON ISSUED A COMPLETELY NEW VIN has absolutely nothing to do with the cab or the frame VIN.
