Vinyl door panels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Proton_Golf2011, Dec 6, 2020.
  1. Dec 6, 2020 at 1:37 PM
    Proton_Golf2011
    Proton_Golf2011 [OP] Member
    2011 pyrite Trd sport
    Blacked out
    My dogs are scratching my panels below the windows. What's the best way to protect from this? Are there precut panels I can buy?
  2. Dec 6, 2020 at 5:29 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Put them in a crate where they belong? It's safer for the dog to be in a secured crate, it's safer for the driver, i.e. the animal is not a distraction or worse, interfering with the safe operation of the vehicle like the retards you see with their dogs on their laps while driving. A secured harness is also a good option if you don't want to use a crate or have room for one.
  3. Dec 6, 2020 at 5:37 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    I think @Proton_Golf2011 was talking about the outside of the door to protect the paint
  4. Dec 6, 2020 at 7:08 PM
    Proton_Golf2011
    Blacked out
    Ok replace dogs with my nephew with down syndrome is scratching the panels under my window. Crates still the option?
    spencermarkd likes this.
  5. Dec 6, 2020 at 7:22 PM
    Bajatacoma
    SC
    Well that's for you to decide I suppose. :drevil: I wanted to put my little cousin in one yesterday while I was trying to work on his dad's truck and he kept jumping in the bed to mess with me; I did threaten to tie him to a tree if that counts.
    They do make some interior panels for some common police vehicles like Tahoes since working dogs tend to get bored and chew up the interiors (usually the upholstery) but I've never seen anything like that for Tacomas. You could always buy a couple of sheets of ABS or Kydex and mold them with a heat gun. Some heavy duty Velcro should hold them in place or you could do something like the screw in snaps if you didn't mind drilling a couple of holes (ex. https://www.amazon.com/20pcs-8-Inch...07310873&sprefix=screw+in+snap,aps,215&sr=8-3). If you mean for the exterior, you can buy sheets of 3M vinyl wrap and do it yourself but I seriously doubt it'd hold up to dog claws for long.
  6. Dec 6, 2020 at 7:43 PM
    DiscoYaker
    SE USA and Alaska
    Guess you are talking about inside the truck then? At first I thought you were talking about the outside door panels.
  7. Dec 7, 2020 at 12:08 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I made a "seat leash" using some 1/2" rope, a carabiner, and this "bottle opener" for my dog. https://www.amazon.com/dp/B07HKSBCG3/ref=cm_sw_r_cp_apa_fabc_rgEZFb555K12P?_encoding=UTF8&psc=1
    For the OP's problem, a a piece of cut and bent ABS attached by hook and loop fasteners (e.g. Velcro) is the first time that comes to mind. ABS bends pretty nicely when heated so I imagine you could form it (on a vice or your workbench) to fit the inside door areawhere I'm imagining your dogs would jump up pretty well. Then attach some adhesive hook and loop fasteners to the door and the ABS and you're good to go.
