Vinyl wraps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 415raf, Jul 12, 2016.
  1. Dec 6, 2016 at 12:33 PM
    #41
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    You don't need to scuff up for plastidip.
    While it would be easier, the plastidip hardens and cracks over time being in the direct sunlight like that. I did my grille a few years back and it's flaking off now. Easy to re-do though.
    If you're patient and have help wrapping the roof would be easy. Pull the weatherstripping, antenna (if you have one) and the third brake light. If you get quality vinyl (3m or Avery) you can lift it up and lay it back down as you go from one end to the other. From what I've read, it takes 24 hours for it to fully adhere to the surface. Use a heatgun to help contour it to the lines in the roof and some soft of rubber squeegee
    BlkTaco47[QUOTED] likes this.
  2. Dec 6, 2016 at 12:54 PM
    #42
    AustinNative
    AustinNative Swollen Member
    ATX
    2017 MGM TRD Sport DCSB
    Maxtrac spindles OME 885s Bilstein 5100s all around (adjustable front/extended length rears) Maxtrac rear blocks Headstrong Taco lean spacer OME CBD SS brake lines InsaneFab CMC 18x12 Fuel Hostage 35x12.50 Maxxis AT 1.25" Spidertrax spacers in the rear Llumar Ceramic Tint (5% Rears & Back / 18% Fronts / 50% Windshield) Toyota Tri-Fold bed cover and OEM bed mat Triple Black Clazzio seat covers WeatherTech laser fit or whatever the fuck they call em Probably other stuff...
    Please never, ever, ever scuff a surface before dip. You will create a nightmare scenario when removing, and basically turn something that's designed to be temporary into a long term pain. If you're going to take the time to prep anything, just go all in and paint. Otherwise, just clean very very good, and dip away.
    ozpall, Error 418, ChemDawg and 3 others like this.
  3. Dec 6, 2016 at 12:57 PM
    #43
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    lol, not sure what I was thinking, maybe when I was going to do my wheels.
    I was just thinking about it and I didn't do anything other than clean really well
    when I did my grille a year ago. brain fart moment!
  4. Dec 6, 2016 at 1:02 PM
    #44
    AustinNative
    ATX
    Happens to the best of us. I dipped some 17" bronze wheels in white, and had them last a year still looking good. Used 1 can per wheel. The cleaner that they sell on DipYourCar.com called "Brake Dust Professional" or BDP is LEGIT for future reference.
  5. Dec 6, 2016 at 4:48 PM
    #45
    DarkMeatTaco
    DarkMeatTaco Well-Known Member
    St. Pete, FL (Da Burg)
    2016 Negro/Negro TRD Sport
    you don't have remove anything. all you have to do is create seams around the brake light and the fin. just make a slit and then tuck the vinyl around the fin.
  6. Dec 6, 2016 at 4:51 PM
    #46
    DarkMeatTaco
    any good installer would be able to do this in 90min. if you need someone in central FL, pm and I can put you in touch with my boy Tony from SKYWAY WRAPS.
    Big Brutus likes this.
  7. Dec 7, 2016 at 1:59 AM
    #47
    BlkTaco47
    BlkTaco47 Unhinged
    Anyone here in Va know of a reputable shop?
  8. Dec 20, 2016 at 11:20 PM
    #48
    steeeben
    steeeben Member
    2017 Toyota Tacoma TRD Off-Road
    Can you upload more photos please? I got a white 17' Taco and debating whether or not to black out the roof to blend in with my moon roof or to just leave it as it.
    ChadsPride likes this.
  9. Dec 21, 2016 at 7:03 AM
    #49
    su.b.rat
    su.b.rat broken truck
    been planning to do that to my roof on my white Pro, lots of high contrast black & white, but thinking it may be a bit too much... and it's around $400 to have it done professionally.
  10. Dec 21, 2016 at 8:05 AM
    #50
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Line-X the hood and roof for between $550 to $675 and would take about 3-4 hours to complete. And never have to redo nothing again.
    Line-X of Southwest Illinois
    618-222-1800
    Providing Solutions for All Your Protective Coating Needs.
  11. Dec 21, 2016 at 8:56 AM
    #51
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    That might be a bit more commitment than vinyl and dip customers really want.
    Skydvrr, ChemDawg and stealthmode like this.
  12. Dec 21, 2016 at 9:09 AM
    #52
    CusterFan
    This is true. You just cannot change your mind and peel Line-X off. I don't have the money to keep replacing vinyl when it wears out and as I get older I don't want to wax either. To each his own.
  13. Jan 3, 2017 at 12:09 PM
    #53
    MilesToEmpty
    MilesToEmpty Well-Known Member
    Charles
    Frederick Co, MD
    '13 Baja TX
    Wheelers Progressive AAL, Firestone RideRite airbags.
    How easy are the window seals to remove? Wanting to go with a desert tan.
  14. Jan 3, 2017 at 12:12 PM
    #54
    AustinNative
    ATX
    On a scale of 1-10 I'd say a 2. Once you get the first one off you're gonna be like "that's it?"
  15. Jan 5, 2017 at 7:36 AM
    #55
    Havanero
    Havanero Active Member
    When you get a chance you need to post more pics. Thanks
  16. Jan 5, 2017 at 11:42 AM
    #56
    Aaronp18
    Aaronp18 Well-Known Member
    Vancouver, BC
    2016 White Tacoma TRD Sport 4x4 DCLB
    @steeeben Here's some more pics for you guys! A bit dirty but it's abnormally cold here for the area and I haven't washed it in weeks.
  17. Jan 5, 2017 at 11:45 AM
    #57
    su.b.rat
    ^ i'm actually trying to get my white Pro's roof wrapped just the same. i've been trying to about a month but the wrap people around here are total flakes and i haven't been able to set it up yet. it looks great in that pic, so thanks for the encouragement!
  18. Jan 5, 2017 at 11:50 AM
    #58
    Aaronp18
    Vancouver, BC
    Thanks!
    I'm thinking of altering the grilel now and painting the grid satin black to match as well. Not digging the colour match portion anymore, I vinyled it and it's starting to crack in places. Would love the Pro grille but don't want to pay $400 for it.
  19. Jan 5, 2017 at 11:52 AM
    #59
    su.b.rat
    agreed, why don't you go with a mesh black grill insert? i think you can find them for around $100 or something.
  20. Jan 5, 2017 at 11:53 AM
    #60
    Aaronp18
    Vancouver, BC
    That's probably the next option, paint I already have. Just need the time to get it done!
