Violent shaking around 50
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4X4 aggie '13, Jun 27, 2010.
  1. Jun 27, 2010 at 11:33 AM
    4X4 aggie '13
    4X4 aggie '13 [OP] Well-Known Member
    College Station, TX
    09 4x4 TRD OR
    3" toytec spacer lift, n-fab steps
    Ok I'm stuck in the middle of no where. My truck starts shaking around 50 and gets worse as I acclerate. I'm running on my spare but it wasn't doing it before I went mudding and got stuck and my dad had to pull me out. So I think it happened when I got stuck mudding do yall know what might be wrong please let me know soon! Ps I checked my lug nuts they are fine and alignment looks fine.
  2. Jun 27, 2010 at 11:39 AM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    Is there still mud in your wheels. Mine always shakes until I can get the dirt out. Throws the balance of the tires off.
  3. Jun 27, 2010 at 11:39 AM
    AK27
    AK27 Well-Known Member
    any mud caked in your rims?
  4. Jun 27, 2010 at 12:07 PM
    cobrakenny
    cobrakenny Well-Known Member
    Ken
    Raleigh, NC
    09 TRD Crew Cab 4x4 LB
    x3 on the mud caked on the tires/wheels!!!
    Just a small bit of mud=a wheel weight. First depending on how agressive your tire tread is, check for stones stuck in the treads, if not then take it to a car wash and clean all the mud off from the outside AND the inside of the wheels. If stiil not the solution then maybe the spare was out of balance to begin with?
    Good luck! Let us know how you make out.
  5. Jun 28, 2010 at 4:40 PM
    4X4 aggie '13
    College Station, TX
    09 4x4 TRD OR
    Thank yall so much! After reading yalls posts I went to a near by self serve carwash and blasted my tires with the pressure washer and it was fixed. :D
