Violent shaking in 99 taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sam99Taco, Apr 7, 2024.
  1. Apr 7, 2024 at 8:21 PM
    Sam99Taco
    Sam99Taco [OP] Member
    Sam
    1999 Tacoma Sr5 4x4 5 speed manual with 2.7l
    Rims, cold air intake, exhaust, brush guard, pioneer speaker, boat speakers
    I have a 1999 Tacoma Sr5 4x4 and I’ve replaced the rear shock absorbers on the truck as-well as the front shocks and springs and the front cv joints too, I’ve also put a new rack and pinion on the car and all new braking system (both front calipers front pads and rotors, rear drums and rear drum shoes as-well as new wheel cylinders) I’ve also replaced the passenger side wheel bearing. But ever time I go to brake and slow down the whole car will violently shake whenever I use the brake normally but then I nearly touch it it’s fine or if I slam in the brakes it won’t shake. It’s getting very violent and not safe to drive. Would anyone have any ideas on what could cause this?
  2. Apr 8, 2024 at 6:25 AM
    Papa Surf
    Papa Surf Well-Known Member
    Galveston, TX
    1999 3.4L Prerunner. 2nd Owner since 2001.
    Possible worn-out carrier bearing?
  3. Apr 8, 2024 at 6:41 AM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    Were all the new parts an attempt to solve this or did it start after some new parts?
  4. Apr 8, 2024 at 6:44 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Recheck all the parts you replaced maybe you left something loose.
  5. Apr 8, 2024 at 6:07 PM
    Sam99Taco
    Sam
    All the new parts were to attempt to fix this shaking and I’ve gone over everything a million times. I’m not sure if it is the carrier bearing which is original on the truck
  6. Apr 8, 2024 at 7:10 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Mine did the same
    my LSPV was bad
    Causing truck to stop with 100% front brake bias
    Did you see the wear difference between drums and front pads?
    Mine: drums 2% wear
    Pads. 70% wear
    did the $45 delete with manual rear brake control valve (jegs)
  7. Apr 8, 2024 at 7:36 PM
    Sam99Taco
    Sam
    I just checked and my carrier bearing is shot, I’m not sure about the brake pads I just redid them and they seam fine, the original shoes were pretty good still but I swapped them anyways and I do know that if I brake using the e brake to test out the rear it does cause the truck to shake aswell while driving and stopping
