Viper 690xv install
Discussion in 'Technical Chat' started by rab89, Feb 21, 2010.
  1. Feb 21, 2010 at 4:04 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    So, I just pulled the viper 690 xv out of my mustang to put in my Tacoma,
    I didn't have the alarm installed in the mustang, but who ever out it in added some relays and weird wiring to the alarm system. All I really want to use the alarm for is to unlock the doors, so, Can I hook it up without the alarm part and just put the door lock/unlock mechanism in?
    Thanks.
  2. Feb 21, 2010 at 4:25 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    there are also 3 relay's that seem to be added aftermarket, can I just delete those?
  3. Feb 22, 2010 at 12:15 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
  4. Feb 22, 2010 at 1:43 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    help
  5. Feb 22, 2010 at 1:49 PM
    vatechoma
    vatechoma Well-Known Member
    Darryl
    Richmond, VA
    06 DC Off Road
    I have a different alarm system hooked up on my other car and I am just using it for lock/unlock...I'm sure it can be used as just that..if it gets too confusing, you can buy really cheap keyless entry units on ebay and Amazon that have basic hookups and directions....sorry if this isn't much help
  6. Feb 22, 2010 at 1:50 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    thats good to know, I may end up just buying a keyless entry unit. would you suggest any specific unit?
  7. Feb 22, 2010 at 3:14 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    ok I have a bunch of info, any electronic guru's I need your help.
    from the main harness that comes from the box, these are the wires and where I think they go and what they are called.
    Red (+) "12 v power input" battery or fuse box
    Brown (+) "siren" self explanatory
    Yellow (+) "ignition input zone 5" I know that it goes to a relay, then to the ignition somewhere?
    black (-) "ground" self explanatory
    blue (-) "instant trigger zone 1" don't know where it goes
    purple (-) "door trigger zone 3" don't know where it goes
    white (-/+) "parking light output" don't know where it goes. maybe to the "brain" relay
    orange (-) "500 ma armed output"
    so, I have 1 relay that just has power running to it, and then from it there is one open spot, which connects to the power for the door lock port, I think.
    I have a negative relay that gives ground to the door lock port, then there are 2 open spots, my guess is the blue (-) instant trigger zone 3 wire goes to one, and the purple (-) door trigger zone 3 wire goes to the other spot.
    Then I have what seems to be a brain relay, there is a green wire coming from it that went to the ignition area on the mustang, and a black one that I'm assuming is ground. then there is a spot for the yellow (+) ignition input zone 5 wire, and a spot for the orange (-) 500 ma armed output wire. then I have an open spot, which I'm assuming is for the white (+/-) wire (does the (+/-) mean it can go to either a poss or neg?)
    I think that's all I have, does that all sound right?
    Thanks in advance!
    Ross
  8. Feb 22, 2010 at 3:38 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    I know someone will be able to help on this one, also, how do I know which wires to tap into for the ignition and door lock wires? is there a wiring diagram somewhere I can follow?
  9. Feb 22, 2010 at 3:41 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    Look around online for websites selling keyless entries for your specific truck, and see if they have install PDF's available. That will probably give you an idea of what needs to go where.
  10. Feb 22, 2010 at 3:44 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    thanks, I'm on it!
  11. Feb 22, 2010 at 4:07 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
  12. Feb 22, 2010 at 9:39 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    oh come on!
  13. Feb 22, 2010 at 10:00 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    oh well Customtacos guys will know.
  14. Feb 23, 2010 at 8:45 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    Do you have a tester? test the wires.
    Sorry I would tell you yes or no the diagram is right, but I really don't know. Trial and error buddy..
    Good luck :thumbsup:
  15. Feb 23, 2010 at 4:18 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    I do have a multimeter, I'll tackle it tomorrow morning
