Visor Sticker Removal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by victorye3, Jan 20, 2008.
  1. Jan 20, 2008 at 9:15 PM
    victorye3
    victorye3 [OP] Western Alliance-NorCal
    Fresno/Tulare, CA
    06 PreRunner SR5 TRD Off Road
    Has anyone removed their warning stickers off of the visors? It looks like ill rip the fabric if I try to remove it.
  2. Jan 21, 2008 at 2:10 PM
    dbbd1
    dbbd1 Well-Known Member
    I think that they are silk-screened on. Maybe some chemical can remove them but would probably remove most of the visor too. I have thought about using some type of vinyl coloring spray to cover them though.
  3. Jan 27, 2008 at 9:14 PM
    dbbd1
  4. Jan 28, 2008 at 1:35 AM
    Dave Russell
    Dave Russell Active Member
    Tacoma 4x4
    Hi there "Visor sticker haters" (I'm the grandaddy of them all) There is a good tutorial on Tundra solutions but basically.....
    1. Take sunvisors off-2 screws
    2. Use steam iron or clothes steamer over a damp towel to steam off stickers. It takes a while to get them loose enough to peel off but by picking at the corner you can get a grip on the sticker and peel it off in one piece.(sort of like stipping vinyl wallpaper)
    3. use 3M adhesive remover spray to soak the adhesive. You can place a damp towel over the spot to keep the 3M from evaporating too fast or just keep wetting it down. I then used a putty knife held at right angles to the visor and scraped back and forth lengthwise over the adhesive area.Wipe the area with a terry face cloth frequently-this picks up the adhesive. I finished up by wetting it down again with the 3M and brushing the adhesive with a BRASS BRISTLED DETAIL BRUSH and wiped it with the facecloth.
    I know...that visor cloth doesn't look too tough but it is and if you scrub enough you will get all the glue off. I did my 07 about 3 months after I got it so there wasn't much of a "shadow" where the sticker was and this has faded to nothing since then. I was pretty nervous about doing this but I couldn't stand those butt-ugly things looking down at me! I was REALLY pleased with the results.
    Total time- about 1 hr.
    Cost-$8 for the 3M(plus one new facecloth when the wife freaked-out)
    Oh yah- don't smoke when you use that 3M ...it blows up real good!!!!
  5. Mar 6, 2008 at 4:10 PM
    Oilcan
    Oilcan Member
    Lake Elsinore, CA
    08 Access Cab, Prerunner, V6, Auto, SR5, TRD, Black (of course)
    Sirius Stiletto via FM Modulator Relay to OEM Stereo
    In an fit of insanity, I tried to pull off the sticker before researching the subject.
    About 1/3 of it pulled off without too much trouble. But the remaining 2/3 was stubborn and I was left with a tattered edge...
    Then I joined this forum and since learned about the iron on damp towel technique.
    I tried this and the rest of the sticker came off, but left the adhesive where the final 2/3 was, so now I have a shadow of adhesive that looks almost as bad as the tattered sticker...
    Where does one find this 3M adhesive remover?
    I'm thinking of just buying a new visor. When my Taco was delivered, the clear plastic registration pocket had a stretch in it- as if someone put their fat finger in it.
    If I can remove the adhesive, I might keep the visor, but if I can't get the 3m product, I'll just buy a new visor.
    Anyone know what the cost of a new visor is?
  6. Mar 6, 2008 at 6:09 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Gray Right - Access cab - Access cab05-07 $45.56 $32.32 [​IMG] [​IMG] Gray
    Mine are of the vinyl type .. will the steam iron work? I tried a hair dryer (wife's ... not mine) in the cab and it didn't work.
  7. Mar 6, 2008 at 7:41 PM
    gsxr3000
    gsxr3000 Well-Known Member
    08 TRD Sport
    OME Lift Kit, TRD S/C CAI EXHAUST
    i ripped that sucker off and bought the big nuts stickers from ebay last week.
  8. Mar 7, 2008 at 8:27 AM
    Oilcan
    Oilcan Member
    Lake Elsinore, CA
    40-50 bucks isn't to bad...
    Would still like to find teh 3M remover I hear talked about. see if that works. but if the remover costs $10, might just get a new visor.
    Lesson learned.
  9. Mar 7, 2008 at 9:41 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    I used the steamer on my truck, worked like a charm.
  10. Mar 7, 2008 at 11:34 AM
    DOT3
    DOT3 Member
    Try GOOP hand cleaner on the remaining adhesive.
    I had luck with that on my 99's visors.
  11. Mar 7, 2008 at 10:01 PM
    Dave Russell
    Tacoma 4x4
    The 3M spray is available at auto body supply shops-just phone and ask if they carry 3M.
    As for the vinyl visors -this steam method won't work.
    The 3m (or goof off or goop or acetone) will work on the cloth ones but it's gonna take some elbow-grease...just keep putting more on and scrape or brush and wipe off the residue.These products evaporate very quickly so you have to apply them several times while scraping or brushing.Bottom line....it will work if you are careful and keep at it.
    Try a blow dryer on the clear plastic pocket- it should shrink back to normal when it cools off - again -be careful,take it slow and don't melt it or you will be looking for a new visor which will probably have stickers on it!!!!
  12. Dec 8, 2008 at 11:16 AM
    Westdog976
    Westdog976 Well-Known Member
    Frankie
    Las Vegas
    4x4 SR5 TRD Sport S/B D/C Magnetic Gray
    MX black upper and lower girlles, debadged, limo tints, TRD CAI, flowmaster dual side exit cat-back, DRL mod, 33x12.5 Toyo Open Country M/T, 18x9 XD Monsters, 6" stage II pro comp lift, smoked LED tails and third brake light, mag gray eyelids, 5901 viper remote start alarm, one touch window modules, 10,000k bixenon hid headlights, 3,000k hid fogs, 4x4 switch LED mod, RBP nerf bars, weathertech floor liners, muth signal mirrors, avid light bar, kenwood excelon dnx9140 nav
    I really want to remove the stickers but need pix to see if the final product is worth the effort!
  13. Dec 8, 2008 at 11:19 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    It is hard to do a good job. I did mine and I can still tell there were stickers. I'll try to get a few pics of them without the stickers.
  14. Dec 8, 2008 at 11:23 AM
    crawfishsoul
    crawfishsoul Look at my member
    Removed front mud flaps.
    Zippo lighter fluid takes most sticky residue off most non-cloth surfaces better than anything else I've used. I used it to clean up after removing pin stripes from my old Wrangler and it didn't touch the paint at all. Obviously test in inconspicuous area first.
  15. Dec 9, 2008 at 1:03 PM
    Westdog976
    Frankie
    Las Vegas
    so no one has a picture?!
  16. Dec 9, 2008 at 1:08 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I forgot to take one, maybe tomorrow
  17. Dec 9, 2008 at 1:09 PM
    Westdog976
    Frankie
    Las Vegas
    thanks bro! can't wait
