Visual Difference Between Locking (TRD) and Non-Locking (non-TRD) Rear End
Discussion in 'Solid Axle Suspension' started by gpack, Aug 21, 2018.
  1. Aug 21, 2018 at 9:54 AM
    gpack
    gpack [OP] Tacoma Owner
    I have an '04 Tacoma non-TRD and note how the rear end is configured. The bed had damaged repaired years back by a previous owner and I am not sure if the rear end may have been swapped as a result of the damage. Could someone post a photo front and back of the non-locking and locking rear ends?
    Thanks
  2. Aug 21, 2018 at 4:12 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    The locking rear end has a small motor on the left side of the 3rd member on the outside of the pumpkin. And a bunch of wire in a wiring harness.
  3. Aug 23, 2018 at 7:57 AM
    Taco crazy
    Taco crazy Well-Known Member
    Chattanooga TN
    '97 Tacoma std cab V-6
    Locked front and rear, bumpers, sliders, cage etc..33" Cooper STT PRO's. Mild suspension lift.
    On 1st gen trucks the E-locker rear has it's drain plug is on the Driver's side of the housing and the NON-elocker is on the pass side.
  4. Mar 9, 2019 at 5:39 PM
    gpack
    Waaaaay late reply from me, but thank you for this input.
