VLEDs LED switchback / super bright DTRL / bulbs TRITON GROUPBUY
Discussion in 'Group Buys' started by ambiguous, Jan 16, 2014.
Thread Status:
Not open for further replies.
  1. Apr 11, 2014 at 2:13 PM
    #241
    Naholo808
    Naholo808 Well-Known Member
    Jordan
    9th Island (Las Vegas)
    2020 4Runner Off-Road
    2020 Toyota 4Runner Off-Road 3inch lift 33s Ko2s Matte black SCS SR8 2013 Tacoma TRD Sport 2wd - Traded In.
    It came with one white wire for dimming headlights; however, I don't know which side to put it on. If I put it on one ballast will that dim both?
    Unless VLEDs forgot to add another white wire for both sides?
    I'll post up pictures on sometime next week.
  2. Apr 11, 2014 at 2:43 PM
    #242
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Each pigtail bundle will come with a white resistor wire to tap into Driver and passenger headlight positive wire to dim 50% when HL are on..you mighta' got the wrong part ..call VLED..tech support is great..tell em you are from the TW group buy...
  3. Apr 11, 2014 at 2:56 PM
    #243
    Naholo808
    Jordan
    Just got off the phone with customer service, and I explained that I only received one dimming wire. The rep informed me that I needed two wires and apologized for the missing piece. VLEDs will send me another wire -- no charge!
    I'm impressed with VLEDs customer service -- Very professional, helpful and really cares of their customers. Definitely will order other lights in the future (signals? Sure!).
  4. Apr 14, 2014 at 12:50 PM
    #244
    Naholo808
    Jordan
    What size ttaps did u use?
  5. Apr 22, 2014 at 12:52 PM
    #245
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Can't remember exactly..take your white wire into Autozone and they can match up the gauge for you...the Positive headlight wire is about the same gauge as the white resistor wire..!;)
  6. Apr 22, 2014 at 9:57 PM
    #246
    JoseyWells
    JoseyWells Well-Known Member
    Joe
    Corona, CA
    12 prerunner
    Demello sliders, Icon ext coilovers, icon rear shocks, icons UCAs, 17" Konig Countersteer Type X, 285/70/17 Nitto Trail Grapplers
    installed my switchbacks last night and my truck is looking sweet. ill try to post some night shots in a couple of days
  7. Apr 23, 2014 at 12:05 AM
    #247
    Naholo808
    Jordan
    It's bright isn't it? Still need to hook up my dim wire. Did you install yours?
  8. Apr 23, 2014 at 1:49 AM
    #248
    JoseyWells
    Joe
    Corona, CA
    12 prerunner
    no just left them off. havent driven at night yet tho. so not sure how bright i will blind people
  9. Apr 23, 2014 at 11:50 AM
    #249
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    I have the 5K's, and before I dimmed them I was getting flashed by oncoming vehicles constantly...
    ..first off it's unsafe, and second it's just rude...don't be that guy...the dimmer wire was part of the kit for a reason..
  10. Apr 23, 2014 at 3:57 PM
    #250
    Naholo808
    Jordan
    I still need to do mines -- I'm running 6k.
    Do you have pics on how you did your dimming wires. I've read ttaps aren't good? Thanks
  11. Apr 23, 2014 at 6:03 PM
    #251
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    I ran TTaps for a while with Zero problems, installed correctly they are very effective....I stripped my HL wire back and soldered my connection with my new setup...don't be scared to try...you are not going to hurt anything..its a simple wire connection.
  12. Apr 23, 2014 at 6:51 PM
    #252
    JoseyWells
    Joe
    Corona, CA
    12 prerunner
    I guess im gonna be THAT guy for like a couple weeks jk ....talked to Burt and he said my retrofit should be done in 3 weeks
  13. May 29, 2014 at 6:50 PM
    #253
    Goose8651
    Goose8651 Well-Known Member
    DFW
    2013 Double Cab
    Any chance of another group buy? Would love to buy a set of switchbacks!
  14. Jun 28, 2014 at 11:45 AM
    #254
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Your DTRL circuit is off when your headlights are on. They are likely flashing you due to your headlights. With the diffuser lens of the signal light, there is no way the light is intense enough for folks to be flashing you driving by in the daylight/twilight, and nighttime you should have your headlights on. (unless they are drunk folks walking by your truck)
  15. Jun 30, 2014 at 1:28 PM
    #255
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Uhhh don't know what truck you're talking about...DTRL's are on when HL is on...:crazy:..and obviously you've never seen the VLED 5000 kelvin LEDs, they are intense, and the light output is exacerbated by the reflective bowl....you sure you're not drunk...?:cheers:
    Headlight on...DTRL on...(Pic taken in full sunlight with filter)
  16. Jun 30, 2014 at 8:29 PM
    #256
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Must be an update on 2012 and up models, or a US model feature. My 2005 Cdn model DTRL is off when the Headlight is on, and I know up to at least 2009 that is how it works. Yes, have the VLEDs V3 Switchback, Type 2, 5000K. not drunk...yet. :cheers:
    Checked on it on Toyota User Manual site. DTRL definitely not designed to be on when headlights are on.
    Might want to check with VLEDs on this. I know my 1st gen Triton V3 do not do this, but I also did not connect the dimming wire to my headlights either, though I understand some of you with Version2 are getting the DTRL to come on when the headlight is on as well without the dimming wire connected.
  17. Jun 30, 2014 at 11:44 PM
    #257
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    Because of Canadian law requiring DRL's, I'm assuming that's the key difference in necessitating the dimmer wire. I know with my 2014, I have all off, DRL, Parking Lights Only, and Headlights On. In DRL and Parking Lights, the DRL bulbs are full intensity, with the headlights on, the bulbs dim significantly, fully illuminating again only when the turn signal is activated.
  18. Jun 30, 2014 at 11:49 PM
    #258
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Our Cdn Law requires DTRL in the daytime,(we don't get a switch to turn them off) but not at night (ie when the headlights are on.)
    If you don't hook up the dimming wire at all, and with the headlight switch in the On position, are the DRLs on? (They shouldn't be according to the Toyota Owner's manual, either US or Canada)
    If they are both on at the same time, then with stock bulbs do they function the same way?
  19. Jun 30, 2014 at 11:56 PM
    #259
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    Basically from what I can tell, my 4157 bulbs (I don't have the VLED's yet, waiting for the right time to buy but understanding the theory) are dual filament bulbs. When the headlights are off, both filaments are on (high brightness). When the headlights come on, only the low brightness filament is active. When a turn signal is activated the high filament comes on to indicate the signal (low/high) versus when everything (parking and DRL's) is off in which case it's off/high. Without the dimmer wire to signal the control box to illuminate only to 50% power, there LED's will come on full power. What I'm saying is the difference between Canadian market and US market trucks is, with Canadian trucks, when you turn on your headlights, your DRL's turn off completely. With US trucks, the DRL's remain in a lower power state.
  20. Jul 1, 2014 at 12:02 AM
    #260
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    which is odd, because the manual specifically states that DTRLs are off when the the headlights are on. Nevertheless, your experience explains it, and there is no problem with the VLEDs then, they are operating as expected.
    Perhaps they consider the one low output filament of the 4157 as a marker light, (and the hi filament is used as a signal/dtrl) which would be a change from the 2005-2011 models where only the weak outside corner light is used as a marker light up front.
    Could test this by running the truck, turn on the DRL, then set the parking brake. DRL should go off (2005-2011 it will). If it does go off, then turn the headlight switch to Park, you should see the low filament, come on as a marker light then. That would confirm it.
Thread Status:
