VLEDs LED switchback / super bright DTRL / bulbs TRITON GROUPBUY
Discussion in 'Group Buys' started by ambiguous, Jan 16, 2014.
Thread Status:
Not open for further replies.
  1. Jul 1, 2014 at 12:10 AM
    #261
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    That may very well be it. I'll say the truck has some weird lighting quirks; i.e. fog lights are only available when the headlights are on. TBH, when the headlights are on, the low filament is so washed out by the headlights it probably wouldn't even matter whether they were turned off anyway. But with the VLED's being so bright, the white light it produces is probably why people are getting flashed. I dunno how the truck would react to the test as I can turn the DRL's off completely on the stalk. When I go off duty I'll give it a go just to see.
  2. Jul 1, 2014 at 12:15 AM
    #262
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    What I understand is that Foglights only available when low beams are on is actually mandated by law. All vehicles operate this way from the factory that I've seen.
    Yeah the stock foglights are pretty weak. I notice the difference because they are more yellow (3800K) vs my headllights at 4300K, so you can see the fogs throw light out wide and low right in front of the vehicle. I'd rather have that light while the hi beams are on, or in difficult weather be able to turn off the headlights completely, and just use the fogs, to reduce the reflection from a snowstorm.
    Folks may flash as the two vehicles get close together; the light is very diffused, and from a distance should not be a problem, but up close, yes the VLEDs are bright and do disperse a wide angle. The dimmer wire could be connected to either the Park or Headlight circuit then.
  3. Jul 1, 2014 at 12:18 AM
    #263
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    LOL, every other car I've driven didn't care the headlights weren't on to allow me to turn on the fog lights. I've had Chevy's, Ford's, Dodge's, Mazda's, all of them let me put foglights on once I turned the selector to parking lights (my GLI was different, it was on or off, there *was* no parking light setting!).
    I really wanted to get in on the TRS GB for the morimoto LED fog's, but I need a new desk chair first lol.
  4. Jul 1, 2014 at 12:27 AM
    #264
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    lots of folks mod their tacoma for the anytime fogs. I haven't done mine yet. I've got the parts to convert my fogs to HID in a projector lens, and then I'll need the anytime mod, as HIDs don't like to be turned on/off when switching from low to hi beam.
  5. Jul 1, 2014 at 1:29 AM
    #265
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    Yeah, eventually I'll get around to doing that...for now I'm going to retro so that should give me enough light to not even need my high beams unless the power goes out or something lol...Plus with LED fog's they should be robust enough to handle switching on and off too.
  6. Jul 1, 2014 at 11:57 AM
    #266
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    For those that have noticed the DTRL remains on while the headlights are on, mine are on too.
    I didn't hook up the dimmer switch because my headlights are still brighter <Sylvania ultras>
    I previously wired a switch for my DTRL to prevent the original bulbs from burning out the housing. so I can use my switch to cycle them on and off as I please.
    I also have the anytime fog light mod.
  7. Jul 31, 2014 at 11:46 AM
    #267
    JC0352
    JC0352 Well-Known Member
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    So are these DRL on (white) if you switch on your DRL, or your parking lights?
    If I understand correctly (on a stock '14 tacoma) DRL are the amber lights closest to the grill. The next position on the selector is parking lights; the DRL lights and the little amber lights on the corners are lit up. Is that correct?
    Can you run these white DRLs like you would stock, without the little parking lights on the corners illuminated?
  8. Aug 2, 2014 at 10:00 PM
    #268
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I know the time frame is up for this but can we still order these?
  9. Aug 3, 2014 at 6:19 AM
    #269
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    I'd love to see another GB set up...
  10. Sep 22, 2014 at 11:11 PM
    #270
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
  11. Dec 18, 2014 at 11:49 AM
    #271
    enrohT5
    enrohT5 Well-Known Member
    Bump for a new groupbuy.
  12. Dec 18, 2014 at 8:36 PM
    #272
    SCas
    SCas Well-Known Member
    Stefan
    Bothell, Wa
    14 Pyrite Mica TRD Sport
    SCS 17" SR8 Matte Dark Bronze wheels, ECG Fabrication Raptor Style Grill, Rechelon Retrofitted headlights -3" FXRs with Panamera Shroud, SDHQ A-pillar mounts with Rigid Midnight edition pods, Weathertech mats, XB LED fogs, Nfab 3" Nerf Bars, Clazzio Seat Covers, Jumper's LEDs reverse, dome and map lights, smoked tail lights, tinted, Salex center console and glovebox organizer
  13. Dec 18, 2014 at 8:41 PM
    #273
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    I'm in for a new GB.....
  14. Dec 18, 2014 at 11:10 PM
    #274
    tacodane
    Dane
    To bad I ordered my kit already.lol
  15. Dec 20, 2014 at 2:56 PM
    #275
    WestCoastCole
    WestCoastCole Well-Known Member
    Steven
    Victoria, British Columbia
    2014 SR5 Debadged
    If new group buy, I'd be in.
  16. Dec 31, 2014 at 9:16 AM
    #276
    enrohT5
    FYI to anyone interested, VLED is running a 15% off special for NYE.
  17. Feb 8, 2015 at 5:19 PM
    #277
    tacodane
    Dane
    Best lights I bought9be6b2a5250ca0a99e57c3bd48593a68_42698d93849151b69eba8f3a890e858a137eaa38.jpg
  18. Feb 13, 2015 at 5:35 PM
    #278
    ScarabMike
    ScarabMike Well-Known Member
    Fleming Island
    TRD Offroad
    All stock
    Has anyone had an issue with the new gen 2 controller blowing the turn signal fuses?
  19. Feb 13, 2015 at 6:06 PM
    #279
    tacodane
    Dane
    No issues here.
  20. Feb 13, 2015 at 6:36 PM
    #280
    2007TacBorla4X4
    2007TacBorla4X4 Well-Known Member
    Bob
    Jax, FL
    TRD Sport 4X4 Short Bed
    Borla cat back, K&N cold air, Silver star bulbs, Nerf bars,NEW BFG, Weather teck windows, Flash light on the drivers seat, TRD off Road ft tow hook, Rear driving lights on bumper, Weather teck windows & ft bug guard, 4X4 switch glows, Windows tinted 20% sun shade
    Mine are about a year old. No issues eather...
Thread Status:
