VLEDS VX3 Gen 2.0 Fog lights.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neverstuck, Feb 24, 2016.
  1. Feb 25, 2016 at 9:35 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Again.... If they pull all of 22 watts per bulb there is no way you are getting 2800 lm pee bulb after going through the driver.
    And good point on the cutoff.... Those things are aiming way up!
  2. Feb 25, 2016 at 9:47 PM
    Chris135
    Chris135 Well-Known Member
    Regina,Sk
    2011 Tacoma DCLB SR5 TRD Sport
    Debadged Bilstein 5100 shocks in front OME 885 coils Icon 1.5"aal 16" fj cruiser Trd rims 285/75/16 duratrac tires 1.25" spidertrax wheelspacers (4) Tinted front windows Grillecraft upper grille Custom Trd boxside decals Allpro front bumper Piaa 510 fog lights Box mounted ammo can Rear diff breather BHLM Tinted front windows Rolltop tonneau cover Hand controls (for wheelchair users)
  3. Feb 25, 2016 at 9:58 PM
    neverstuck
    neverstuck [OP] Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    You adjust them by moving the base, thus moving the post deeper into the housing towards the front of the lens, or further away from the lens by adjusting the base. You basically make it longer or shorter so the the beam is focused or broadened much like adjusting the beam of a mag lite. You dan't change their direction from what I understand.
  4. Feb 26, 2016 at 3:11 AM
    Chris135
    Regina,Sk
    Then those aren't the exact ones in thinking of. There was set we installed, or corrected rather that the leds were supposed to be faded in a certain direction so they hit the bowl right and created a proper cut off line
  5. Feb 26, 2016 at 5:16 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    did the same thing, :thumbsup:, was leaning amber to match DRL, but order yellow for more light output. amber is darker and may reduce some output IMO.
  6. Feb 26, 2016 at 8:45 AM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Heard back from VLEDS... This doesn't matter much to me at this point but since you're very confidently denying the claims on the website, I just want to make sure people aren't getting misinformation from your posts about the VLEDS.
    Hi Matt,
    The actual lumen measurement is around 2800lm in vehicle applications. They are indeed 15W chips but they are not running at the full power level. It's common to describe an LED chip by it's maximum possible power rating.
    The 3600 max refers to the maximum possible output in a perfect environment - this is how a lot of competitors rate their products which isn't really fair as vehicle applications are usually a higher temperature environment. It's why we show it on the product page even though 2800lm is closer to the actual output.
    Hope this information helps. Please let us know if you have any other questions or concerns we can help with.
    … 2800 LM per single H11 light assembly and not per pair of fog
    lights, correct?
    Yes. 2800lm each.
  7. Feb 26, 2016 at 9:15 AM
    nd4spdbh
    SoCal
    id be impressed if they did 2800LM per bulb at the 21watts they are pulling.
    but still... shitty throw, shitty cut off, shitty aim... and way blue color, not my cup o tea.
