Volant CAI installed on 2015 4.0
Discussion in 'Performance and Tuning' started by BCfishTaco, Oct 9, 2016.
  1. Oct 9, 2016 at 4:56 PM
    BCfishTaco
    BCfishTaco [OP] Well-Known Member
    Beautiful BC Canada
    2019 DBL TRD Sport Silver
    I just finished the install and for a non gear guy it was very easy. I did have to dremel one spot and a few other minor rubs to get the bolts to line up. The kit came complete with everything I needed. I didn't get the RAM air scoop version but in hindsight I should have. There is a empty hole where the RAM tube goes on but nothing to cover it with. So I picked up a rubber 3" plumbing closure from HomeDepot. Start to finish just over an hour. I took it for a quick spin around the block and it does sound nice :)
  2. Oct 9, 2016 at 9:12 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    The scoop will draw the same exact temps as ur stock intake, and the same as the volant pulls as it is.
    At approx 40mph the stock intake draws ambient temp air.... buy a scangauge or ultragauge and u can see for urself.
    Save ur money.
  3. Oct 9, 2016 at 11:15 PM
    BCfishTaco
    Beautiful BC Canada
    Thanks for the tech info bro. Getting it scoop separately is double of what it cost in the complete kit so I won't bother with it now. This makes me feel a lot better about that decision.
  4. Oct 9, 2016 at 11:19 PM
    inwood customs
    Dave
    Ur welcome... ive had some doubters, but the simple way to check is watching temps with 1 of those gauges, or even a smart phone and a cheap $5 obd2 wireless adapter.
    Cruising at that speed rlly does pull ambient... and ive seen heatsoak vanish with just a semi amount of throttle effort... all ya gotta do is give er a lil oomph if u dont see the temps go down, and the soak is gone.
    Amazingly even the k&n draws ambient and its got a pretty weak design imho.
    Enjoy!
  5. Dec 30, 2016 at 9:32 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I just ordered mine, I did get the scoop because of all the sand I'm sucking up from the wheel well.
    The scoop should allow more and cleaner air flow. But we will see.
