volant cold air intake, engine light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by k2jacob789, Apr 5, 2011.
  1. Apr 5, 2011 at 8:58 PM
    k2jacob789
    k2jacob789 [OP] Member
    hi folks i have a question, i just installed a volant cold air intake, i relplaced my k & N that i had. i noticed a little difference when i changed it over to the volant. the next day the engine light came on. i took it to the mechanic and he hooked up his computer to it, it said something like " lean air" can't remember exactly what the error said. he reset it the later in the day it come on again. any suggestions
  2. Apr 6, 2011 at 2:22 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Well if its because its running lean, that means your a/f ratio isnt good and your getting to much air and not enough fuel. And thats NOT good. Unless its just throwing that code and its wrong?
  3. Apr 6, 2011 at 2:41 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    I read that same thing about the Volant.
  4. Apr 6, 2011 at 7:13 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    More than likely this. Only known fixes for it are; remove it; or, URD MAF calibrator. My understanding is the the Volant intake's cross section is larger than stock. The stock MAF sensor is calibrated for a specific intake cross section. Since the Volant is larger, the MAF sensor reads less air passing by then what actually is, and adjusts the fuel to what it thinks is there as opposed to what is actually there. This makes for a lean condition.
  5. Apr 6, 2011 at 7:49 AM
    k2jacob789
    guys what should i do about the check engine light situation. i'm i damaging my engine
  6. Apr 6, 2011 at 7:49 AM
    k2jacob789
  7. Apr 6, 2011 at 8:43 AM
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    The only way to fix that problem is the URD MAF Calibrator!:D
  8. Apr 6, 2011 at 8:45 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    but the MAF calibrator only works in an OPEN LOOP. (above about 2000 RPM) just FYI.
    and i have the Volant intake...anyone want it??????
  9. Apr 6, 2011 at 9:24 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    But in Closed loop, the AF ratio is more driven by the O2 sensors. Again, according to what I've researched and read, as I have no actual experience with the Volant.
  10. Apr 6, 2011 at 9:34 AM
    babbott
    babbott Foxtrot Uniform Charlie Kilo
    Tooele, Utah
    08 off road speedway blue
    make sure the MAF sensor is as vertical as possible. I had the same problem and after some adjusting to the intake tract mine seems to have gone away. The intake tract tube is a POS! The mounting for the MAF is the worst I have ever seen.
  11. Apr 6, 2011 at 12:21 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    That is the truth...
  12. Apr 6, 2011 at 12:26 PM
    K1992f
    K1992f Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    Ok looks like I'm not buying this S$&T .... Almost did today
