Volant Intake installed
Discussion in '4 Cylinder' started by prdltakid, Jan 21, 2013.
  1. Jan 21, 2013 at 10:16 PM
    prdltakid
    prdltakid [OP] Dick Richards III
    Dick
    Kaneohe, Oahu, HI
    08 4x4 5spd Tacoma
    Just installed my new volant intake and seem to have a problem. When she turns over she only runs for about 2 seconds and than shuts off. But when I disconnect the MAF she'll stay running, idel starts off at around 500, than slowly increases to 900 before eventually dropping down to just under 500. Has anyone had this problem? Should I look into getting one of those URD MAF calibrators. Any help would be welcomed. Thank you.
  2. Jan 21, 2013 at 10:30 PM
    Mr. Brown
    Mr. Brown Well-Known Member
    Orange County
    White Double Cab Off Road
    Suspensiopn: Donahoe coil overs, Donahoe rear reservoir shocks, Light Racing UCA's, Wheelers AAL's, Exterior: Powder-coated black billet grill, Hella Black Magic fog lights, color matched rear bumper, color matched side mirrors, undercover tonneau cover, Interior: Alpine W203 w/ Blackbird II, Weathertech Floor-liners, blue gauge light mod, Performance: AFE Stage II Intake, Banks exhaust, single cat y-pipe, Dynomat hood-liner, NST Performance pulleys, URD MAF calibrator
    It is most likely an improperly inserted MAF sensor or a vacuum leak. Check to make sure your MAF sensor is pointing towards the throttle body and sealed well, then check all the other seals on the intake. Make sure air is not leaking in anywhere.
    If that doesn't work try disconnecting the battery for a while to reset the computer.
    If that doesn't work, you may have damaged the sensor during the install.
  3. Jan 21, 2013 at 10:35 PM
    06TRDZombieHunter
    06TRDZombieHunter Well-Known Member
    Robert
    Hillsboro, OR
    06 TRD Sport DCLB
    K&N Intake System Port and Polish of TB x2 E3 Diamondfire Sparkplugs 2.5" Leveling kit 32" BFG A/Ts Zombie Response decals Custom painted grill, trim under headlights, scoop, intake and manifold. No more mud flaps, Temp gauge inside intake box, BHLM, extra D-rings in front of bed, No more plastic storage box behind rear seats. More to come.
    DONT get one of the MAF calibrators.. It won't fix your problem, and may likely add to your frustrations. It only operates during open loop sessions of throttle, and is designed to richen up the AFR with bold on mods like aftermarket intake and exhaust. I'd get your truck running well again before heading that route.
    -Rob
  4. Jan 21, 2013 at 10:58 PM
    prdltakid
    Dick
    Kaneohe, Oahu, HI
    08 4x4 5spd Tacoma
    Welp, I'm an idiot. Mr. Brown, you were right. Just went out and reinstalled it correctly and tunred over and ran just fine. Idles a little high, but that was the first time I've started it since last night. Thanks for the help.
  5. Jan 21, 2013 at 11:11 PM
    SonDa5
    SonDa5 New Member
    Tacoma
    Could you post some photos of it installed and a sound clip of how it sounds?
  6. Jan 21, 2013 at 11:25 PM
    prdltakid
    Dick
    Kaneohe, Oahu, HI
    08 4x4 5spd Tacoma
    I'll do the photos in the morn. I'll try the sound clip. Not sure how to do that part.
  7. Jan 22, 2013 at 7:28 AM
    Mr. Brown
    Orange County
