VOLANT INTAKE WITH RAM AIR SCOOP
Discussion in 'Performance and Tuning' started by shr133, Jan 15, 2017.
  1. Feb 27, 2017 at 6:22 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Anyone who talks about "tuning" the truck is obviously full of shit. You can't custom tune a tacoma, and plug and play chips are a big joke. People who believe that, also are dumb enough to think a K&N air filter increases HP.
    I've run a Volant intake for over 2 years and have NEVER had any MAF problems.
    running the MAF cal and a unichip makes no sense at all and is the cause of OP's problems. All they do is try and trick the sensors to manipulate timing and the fuel trim in a certain RPM range, but throws off the ECU within other parameters.
    Almost every mod the OP has done, has been proven to NOT gain any performance and there are plenty of threads saying so, if you look.
  2. Feb 27, 2017 at 7:59 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
     say wut?
    :rofl::rofl:
    @Torspd @Gadget@URD @Lucario Runner
    Yall be full of shit
    rmepilot, Rambo54 and Lucario Runner like this.
  3. Feb 27, 2017 at 8:04 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Is this a reverse Cosby I keep hearing about?
  4. Feb 27, 2017 at 8:08 AM
    inwood customs
    Dave
    Nah man, thats JJ up thar
    AZ_Charles likes this.
  5. Feb 27, 2017 at 8:08 AM
    gottaToy
    JJ
    1985 Moped
    You're not tuning a 2010! Gadget hasn't released the uconn for 2009+
  6. Feb 27, 2017 at 8:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes he has. *UCON*
  7. Feb 27, 2017 at 8:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Apparently, I am "full of shit". Bowels aside, that is where the resemblance ends.
    Lucario Runner likes this.
  8. Feb 27, 2017 at 8:13 AM
    gottaToy
    JJ
    1985 Moped
    Still shows out of stock and only up to 2008 tacoma? Op doesn't have UCON, anyway.
  9. Feb 27, 2017 at 8:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only selling them with URD s/c kits, currently.
  10. Feb 27, 2017 at 8:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have a thread in my signature which is in start contrast to your claims as well. Full of dynos and graphs and thingamagig numbers and such.
    inwood customs likes this.
  11. Feb 27, 2017 at 8:19 AM
    gottaToy
    JJ
    1985 Moped
    I still don't understand why the OP uses a unichip AND the MAF cal, if the URD MAF cal lets you "custom tune"?
  12. Feb 27, 2017 at 8:19 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Don't forget about Jimmy's truck. It was a 2010 if I recall, can't cause I'm constipated, and was Toon's using a pro EFI 48.
  13. Feb 27, 2017 at 8:22 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
  14. Feb 27, 2017 at 8:23 AM
    gottaToy
    JJ
    1985 Moped
    What you guys are referring to, is a far cry from what the OP has in this thread. The Volant does not throw MAF faults, it"s a combination of the other stuff OP has done causing his CEL.
  15. Feb 27, 2017 at 8:25 AM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    '09. Tuned using batch fire. Made ~400whp and ~450wtq on a Mustang Dyno.
    Can tune with with either. Unichip usually comes with a preloaded map. He has posted another thread about his "why's " with the Unichip. Lots of info in there.
  16. Feb 27, 2017 at 8:26 AM
    #36
    Lucario Runner
    Robert
    06 Toyota 4Runner
  17. Feb 27, 2017 at 8:28 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Volant has a history since the 2nd gen, intakes, of making the truck run extra rich. Enough to throw off the fuel trims and set a CEL. URD created preloaded maps specifically for the MAF-CAL, to correct this issue.
    AZ_Charles and Lucario Runner like this.
  18. Feb 27, 2017 at 8:29 AM
    #38
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    I was running this exact setup for over a year and not a single CEL due to the intake. I swapped out the scoop for a snorkel and capped the hole for the scoop. Currently still running the volant box with the airflow snorkel. Still no issues with CEL, but it would appear my fuel trims are all over the place watching my ultraguage. I have MAF cal, but not installed yet. I need in install it so I can load a tune that works with my mods. Should have bought the ucon when I had a chance.
  19. Feb 27, 2017 at 8:30 AM
    #39
    inwood customs
    Dave
    Volant has had issues for yrs, search back if u wanna see it.
    Somehow not erryone ran into the cel for some reason.
    Gadget has a.... ready for it?
    Map for the volant to load on the maf calibrator.
    Torspd likes this.
  20. Feb 27, 2017 at 8:46 AM
    #40
    gottaToy
    JJ
    1985 Moped
    Volant HAD issues and changed the tube to relocate the MAF sensor to fix the problem. I know that URD offers different MAF cal loads, it's in the description. Many have put on the Volant since the new tube and have had no CEL. I guess if you really want to try and optimize the engine and have money to burn, have at it. But for the average person, it's a waste of money for little gain. and even then, custom tuning is usually a give and take to get the best results within a specific range of the powerband.
