Volant Lean Fix
Discussion in 'Technical Chat' started by mudthedoor, May 4, 2012.
  1. May 4, 2012 at 8:51 AM
    mudthedoor
    mudthedoor [OP] Sconnie
    Alex
    Forestville, WI
    00 4Runner
    I installed my Volant CAI yesterday and noticed immidiatley that it was running lean via my ultra gauge. There where a couple things that I tried today to improve it and it worked!
    1. Make sure that the MAF is perfectly level, both in the MAF housing and how the air duct is rotated.
    2. I went to napa and bought a complete vaccume hose for the FPR so that you arn't any longer using a butt joint between two hoses
    Next I might try to make an insert to go in the Air duct by the MAF to reduce the cross section of the duct.
    BTW I was at a fuel trim of about -20 to -18 and now I'm sitting about -7.5 to -10!
  2. May 4, 2012 at 8:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Long term or short term trims?
  3. May 4, 2012 at 9:08 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    These are long term sorry
  4. May 4, 2012 at 9:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What are the short terms? On average?
  5. May 4, 2012 at 9:12 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    They tend to range from 1 to -5 I would say around -3.5 on average.
  6. May 4, 2012 at 9:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....so the short terms arent affected too much, but the LT trim is. Interesting.
  7. May 4, 2012 at 9:16 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Yea I dont get it either...
  8. May 4, 2012 at 9:17 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    I will gather more data to be positive but im fairly sure that is correct
  9. May 4, 2012 at 9:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Those numbers are indicative of running rich......Negative being the amount of fuel trim the computer is taking away. Whats your O2 sensors reading? Regardless.....as long as they are in single didgit readings, you should be fine.
  10. May 4, 2012 at 9:55 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Exactly the maf is reading wrong and causing the motor to trim down the amount of gas possibly?
  11. May 4, 2012 at 9:58 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Ill get o2 readings after class, but what should I look for with those?
  12. May 4, 2012 at 10:07 AM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
  13. May 4, 2012 at 10:16 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Its going to happen eventualy but not an option now just had to pay up for school...
  14. May 4, 2012 at 10:29 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    yes that one was sold
    Believe it or not the one I built and yes sold had absolutely no issues! I wanted the volant air duct so it would look right in the engine bay... That one had normal values when tested...
  15. May 4, 2012 at 10:39 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    I think that my last one worked because the air duct cross section was closer to stock than volants...
  16. May 4, 2012 at 11:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It could be a sign that your O2 is on its way out.
  17. May 4, 2012 at 11:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Need to make sre the other systems are functioning propperly before throwing parts at it. Also, The MAF Calibrator only works at WOT (IIRC), so if these numbers are being given during normal cruise, there may be an underlying issue.
  18. May 4, 2012 at 11:06 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Really maf only has control at WOT, well then I could have a crap filled cat or a bad o2... maf claibrator, nvr mind...
  19. May 4, 2012 at 11:08 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Oh, the maf calibrator... I gotcha yea this is just on a typical cruise nothing crazy...
  20. May 4, 2012 at 11:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The MAF Calibrator changes A/F signal under WOT. When the engine is under WOT conditions, or cold (Open loop), A/F is controled by the MAF sensor. When warmed up, and under normal cruise conditions (closed loop) , the A/F ratio is dictated by the MAF, AND the O2 sensors, with favortisim given to the O2 sensors for better ecconomy. If these readings you are getting are under normal cruise operation, then you need to check the O2 sensors.
