Volant Scoop in Cold Weather
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jrahn0822, Nov 27, 2013.
  1. Nov 27, 2013 at 3:59 AM
    Jrahn0822
    Jrahn0822 [OP] Well-Known Member
    Jake
    Iowa
    07 DCLB
    Living in Iowa it's pretty cold during the winter months. Currently it's 5 degrees F where I'm at. I am running a full Volant Scoop system with the dry filter and pre filter. On my scangauge my intake temp is reading only a couple degrees warmer than the ambient air temp while driving. Should I remove the scoop during the winter months due to the excessively cold intake air temp? Does this present any harm to my vehicle with my intake temp being so low? Thanks taco gurus!
  2. Nov 27, 2013 at 8:16 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Volant scoop intake temps are probably only 2-3 degrees different then stock. Temps should not be a concern.
