Volcom Tacoma 2.0 Build Thread and BS
Discussion in '2nd Gen. Builds (2005-2015)' started by VolcomTacoma, Jul 16, 2016.
  1. Oct 7, 2016 at 6:53 PM
    #41
    VolcomTacoma
    VolcomTacoma [OP] Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Prob be easier and safer to just run a pump and have a tank circulating using engine heat. Wouldnt want coolant lines running the length of the truck, pop one and you're boned lol
  2. Oct 7, 2016 at 6:56 PM
    #42
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    That's true. Also allows you to use a two stage heat exchanger and have an extra layer of protection from contamination of coolant into the water supply.
  3. Oct 7, 2016 at 7:05 PM
    #43
    VolcomTacoma
    Jeff
    NorCal
    Exactly, some sort of shell and tube heat exchanger could work, just have to make sure its strong enough to take hits offroad so you dont snap a tube and contaminate it all.
    Im gonna go ahead and just go with "boil some water and dump it in the bucket of cold water so I can shower with warmish water" lol. Could prob just put a bucket on the engine right when I get up, then it warms up as I'm packing up the RTT and everything, then can just shower right before we head out.
    Arcticelf likes this.
  4. Oct 7, 2016 at 7:22 PM
    #44
    Arcticelf
    Gladiator
    Yeah, that's probably a simpler answer.
  5. Oct 7, 2016 at 8:55 PM
    #45
    VolcomTacoma
    Jeff
    NorCal
    I prefer simpler when I can. Complicated shit has a tendancy to break at the worst possible moment. Right now I'm trying to decide if my battery box in the bed could fit the water stuff, and if so, how do I waterproof it all in case there's a leak. Dont really want my battery soaked. Another option is a secondary mounted box for the water along side the battery box, if theres room, which is why I'm leaning towards a mobile box for the water stuff with a quick disconnect electrical hook up
  6. Oct 7, 2016 at 9:19 PM
    #46
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    My brain hurts. Too much smart
  7. Oct 7, 2016 at 9:25 PM
    #47
    VolcomTacoma
    Jeff
    NorCal
    Oh Danny.
  8. Oct 8, 2016 at 4:27 AM
    #48
    Arcticelf
    Gladiator
    I'd keep the battery and the water handling stuff separate.
  9. Oct 8, 2016 at 5:52 AM
    #49
    VolcomTacoma
    Jeff
    NorCal
    Yeah I'm leaning that way as well. Plus I don't think there's room anyways. Im thinking either a hardcase bolted up under the bed, or something low key in the bed
    Arcticelf[QUOTED] likes this.
  10. Oct 15, 2016 at 2:42 AM
    #50
    DannyBFresco
    Danny
    Or roof rack :spy:
  11. Oct 15, 2016 at 11:06 AM
    #51
    VolcomTacoma
    Jeff
    NorCal
    Nah. I'm thinking a 10-20 gallon tank under the bed, between the frame, tucked up out of the way.
  12. Oct 15, 2016 at 12:46 PM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I don't know if you have dealt with this, but have you bypassed your secondary air injection pump?
  13. Oct 15, 2016 at 12:49 PM
    #53
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have had a few people ask me why I haven't done this yet. For durability is the only reason I have not. Just like you. Radiator weight distribution is the only reason I would though. Since my Ron Davis is so heavy when full. Like race trucks. :D
  14. Oct 15, 2016 at 12:54 PM
    #54
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    @VolcomTacoma
    I haven't seen this thread till now, but I'm going to pretend you just created it so I can say, "about damn time, son".
    Torspd likes this.
  15. Oct 15, 2016 at 12:54 PM
    #55
    Biscuits
  16. Oct 15, 2016 at 12:56 PM
    #56
    Biscuits
    Work will have a lot of these parts too.
    Just saying.
  17. Oct 15, 2016 at 12:58 PM
    #57
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @KirkRio , bypassed his with a resistor. Not sure the size or wattage though. He never stated. Hopefully he'll chime in.
  18. Oct 15, 2016 at 12:59 PM
    #58
    VolcomTacoma
    Jeff
    NorCal
    I may or may not already have a box of water pump parts sitting in my garage.
    Hint* I do
  19. Oct 15, 2016 at 1:00 PM
    #59
    VolcomTacoma
    Jeff
    NorCal
    Why would you do that? Out of curiousity.
  20. Oct 15, 2016 at 1:01 PM
    #60
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Say if it goes bad. Since there seem to be so many threads about that pump failing and causing issues. Or if you don't want to have to deal with it and want the extra room.
