Volcom Tacoma 2.0 Build Thread and BS
Discussion in '2nd Gen. Builds (2005-2015)' started by VolcomTacoma, Jul 16, 2016.
  1. Nov 30, 2016 at 5:05 AM
    #81
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mod induced confidence.
  2. Nov 30, 2016 at 5:34 AM
    #82
    VolcomTacoma
    VolcomTacoma [OP] Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Exactly. Even in Hollister, there were a couple rutted out rocked spots that I watched @DannyBFresco 3 wheel over and teeter totter a bit on, the LT just crawled right over it. The second time back up that trail I could tell I was feeling cocky, knowing I could do it no problem.
  3. Nov 30, 2016 at 6:01 AM
    #83
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Another reason why I admire the capabilities of LT suspension.
  4. Nov 30, 2016 at 8:41 AM
    #84
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    How well the 4.88s work with your 295s, or you planning on hitting up dirty-fives asap? Living on an island in Hawaii, I think 4.88 would work, cause we're going short distances anyway. Also wanted to go 295s as well.
  5. Nov 30, 2016 at 8:59 AM
    #85
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Rude.
    T4RFTMFW likes this.
  6. Nov 30, 2016 at 12:17 PM
    #86
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    There is that.
    My thought is: lockers are for when you're already stuck, but knowing it's there will make it easier to get over confident.
  7. Nov 30, 2016 at 3:19 PM
    #87
    VolcomTacoma
    Jeff
    NorCal
    Ok, new plan, apparently I didn't change my order fast enough and they already shipped 4.56 gears. Sooooo do I wanna pay return shipping for 4.88s or just stick with 4.56. Hmmmm.
  8. Nov 30, 2016 at 3:20 PM
    #88
    VolcomTacoma
    Jeff
    NorCal
    I'm just sayin, your ass end kicked up in front of me and one wheel was like 4 feet off the ground, I had a panic moment for you. I didn't tell anyone about you changing your pants afterwords
  9. Nov 30, 2016 at 9:30 PM
    #89
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  10. Dec 19, 2016 at 7:04 PM
    #90
    VolcomTacoma
    Jeff
    NorCal
  11. Dec 19, 2016 at 7:08 PM
    #91
    DannyBFresco
    Danny
  12. Dec 19, 2016 at 8:04 PM
    #92
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  13. Dec 23, 2016 at 2:39 PM
    #93
    Silverbackbeastyboy
    Silverbackbeastyboy New Member
    Rafael
    2010 Toyota Tacoma TRD Sport Long Bed
    Roof Rack MTB setup and Step up bar
    Your truck is awesome man!
  14. Dec 23, 2016 at 2:41 PM
    #94
    VolcomTacoma
    Jeff
    NorCal
    Thanks brother!
  15. Jan 12, 2017 at 11:17 AM
    #95
    VolcomTacoma
    Jeff
    NorCal
    Had a great time at Hollister Hills SVRA this past weekend.
    Grabbed a couple roasts and some potatoes on the way, cooked them in the Dutch Oven. We were all starving so I overloaded the coals and cooked it really fast, even though I wanted to slow roast it all for 3 hours lol
    The new leveler blocks, basically legos, worked great. Parked on as level ground as I could find but was still all wonky, the levelers had the tent almost perfectly level. No more waking up leaning against the wall
    Some posing at the top of the lookout point. Got stuck on the one corner that was crazy muddy, everything else was easy peasy. Thanks to @cbechtold (and his dad :rofl: ) for the tug. A winch or mud terrains and Id have been fine, just went a little to fast and took a bad line through the deep mud.
    And here's @DannyBFresco stuck in the same spot on the way back down (which I made through with throttle control and curse words about mud). His recovery got a little sketch right at the end when his truck decided to slide to the left halfway off the hill while being tugged to the right. Massive butt pucker on everyone part right there, but everyone made it through safe.
    Pismo trip is next on the list. Gotta get some shit installed first :spy:
  16. Jan 12, 2017 at 11:19 AM
    #96
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Check his seat for a hole?
  17. Jan 12, 2017 at 11:21 AM
    #97
    VolcomTacoma
    Jeff
    NorCal
    Definitely a hole with the edges in brown. I took that one photo and then forgot my phone during the recovery because I thought he was gonna go down the hill. The trail went to the right and he was gasing and turning right but the truck just kept sliding to the left down the hill.
  18. Jan 12, 2017 at 11:26 AM
    #98
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just enough mud to scare the shit out of you. Story for the memory books.
  19. Jan 12, 2017 at 11:44 AM
    #99
    DannyBFresco
    Danny
    New upholstery already ordered :anonymous:
  20. Jan 12, 2017 at 11:57 AM
    #100
    VolcomTacoma
    Jeff
    NorCal
    Most definitely. "The day we almost retired El Taco Fresco"
    DannyBFresco likes this.
