Volk racing TE 37 on my tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bukzilveraway18, Aug 24, 2016.
  1. May 10, 2021 at 2:49 AM
    #3021
    _rdpn
    _rdpn New Member
    2017 white Tacoma trd sport
    Spintech exhaust Prinsu roof rack
    Anyone know where I can get these center caps? Located in Hawaii, need em asap
    dallas05taco[QUOTED] likes this.
  2. May 10, 2021 at 5:30 AM
    #3022
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    ok, maybe this is a typo, but why would 265's rub at all. That is nearly a stock size.
  3. May 10, 2021 at 5:32 AM
    #3023
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    265 is width... note the change in height 265/70/17. Also the wheels have a different width and offset than stock, so the backspacing, poke, etc is different.
  4. May 10, 2021 at 5:38 AM
    #3024
    RatDaddy
    Roy
    None
    I completely understand sizing. My point is that no 265 should rub unless your offset and camber settings are not right.
    A 265/70-17 is the same size as a 265/75-16, barely larger than a stock tire. The height change is 1 inch OAL and half an inch when fitted to the wheel. The tire diameter goes up from 30.6 to 31.6, no reason for rubbing at all.
  5. May 10, 2021 at 5:40 AM
    #3025
    jeremy5000
    Philadelphia
    I rub my plastic linings off-road with a 265/75/16 on a 16x8 et0 wheel. Alignment settings are roughly stock.
    RatDaddy[QUOTED] likes this.
  6. May 10, 2021 at 5:45 AM
    #3026
    RatDaddy
    Roy
    None
    Strange. is your truck a TRD? Do you think some negative offset would have helped. I have seen people go with some negative offset on 8 inch wheels.
  7. May 10, 2021 at 8:05 AM
    #3027
    jeremy5000
    Philadelphia
    Not a TRD. Some tires run wider than others. Also a more negative offset would cause more rubbing by pushing the wheel further from the centerline, which will make it hit harder against the cab mount at full lock and stuff. That's why you can fit a skinny 33" on stock wheels but not on most aftermarket wheels without rubbing/trimming.
  8. May 10, 2021 at 8:52 AM
    #3028
    dallas05taco
    dallas05taco Well-Known Member
    Plano
    2018 Tacoma TRD Pro
    @ShowstoppersUSA is where I got mine from
    _rdpn[QUOTED] likes this.
  9. May 10, 2021 at 9:05 AM
    #3029
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Same here
    _rdpn likes this.
  10. May 11, 2021 at 8:20 AM
    #3030
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    Just to be on the safe side I ordered another wheel from @runnin4tacos, perfectly willing to wait the advertised 2 months. To my complete surprise, I got a tracking number yesterday and I should have the spare on Thursday. I don’t know how many more they have, but if you’re looking I’d hit them up.
  11. May 11, 2021 at 8:29 AM
    #3031
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Damn you got me all excited, I need a couple of 16’s though.
    Good looking out though
  12. May 11, 2021 at 1:26 PM
    #3032
    ShowstoppersUSA
    ShowstoppersUSA ShowStoppers Offroad
    Glendale, Ca
    So to further follow up on rubbing when it comes to wheel / tire,
    In theory, a 265/70r17 or a 265/75r16 with the respective spec wheel of 17x8.5 -10 or a 16x8 et0 should not rub on a tacoma as it is a +1 size tire with a fairly conservative wheel spec.
    Generally when people ask about "rub", they are concerned about the cab mount. You *may* see rubbing on the trim under compression or say if that plastic liner did get pulled or say "damaged". Some people have the OEM flaps as well which would contribute to minor plastic rubbing, while others take those off as the first they they do.
    The tire itself is also something, not every tire is the same size when we break it down between mud/hybrid/all terrain. When comparing a Toyo Open Country M/T to say a BFG Ko2, the Ko2 would be a lot more conservative to the size.
    There are quite a few considerations and factors when it comes down to it. If anyone wants to discuss further, please feel free to message us. We've done essentially all the combinations of our spec te's and different tire sizes between the brand. However, @MESO still holds the throne for the 37's on te37's on a Tacoma... :laugh:
  13. May 11, 2021 at 1:36 PM
    #3033
    ShowstoppersUSA
    Glendale, Ca
    As for an update on the Rays orders.
    We are equally, if not, more concerned about outstanding orders and did finally speak with the higher ups as everything is being held up at port due to the congestion. We are finally receiving containers in the order they are produced and fulfilling in the respective order as we receive. Te37xt's (standard and a couple optional finishes) did come in and we did contact everyone who has an open order on those. For the main hot topic at hand, special order Te37x's are set to be unloaded within the next few weeks, the ETA we are being relayed is 2-4 weeks.
    We do apologize for any inconvenience, as all the delays as due to the circumstances at hand is out of anyone's control. With that, we are very thankful for everyone as you guys are rockstars with your patience and understanding. We cannot wait to receive these Te37x's as they are quite special and I'm sure everyone will be absolutely thrilled to have these gems in their hands.
    Phich, TRlPPlN, CreoUCLA and 3 others like this.
  14. May 11, 2021 at 3:23 PM
    #3034
    dallas05taco
    Plano
    2018 Tacoma TRD Pro
    Really wish it wasn't -10 offset tho
  15. May 11, 2021 at 3:36 PM
    #3035
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    Are all X's spoken for?
  16. May 12, 2021 at 4:51 PM
    #3036
    CreoUCLA
    CreoUCLA Well-Known Member
    West L.A.
    '21 Tacoma TRD OR, '21 Audi TT, & '22 Tesla M3P
    Now I'm just patiently waiting for the Volk/Rays center caps and lug nuts from @ShowstoppersUSA so I can install them. :D
  17. May 12, 2021 at 6:07 PM
    #3037
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Ive got my Ray's lugs and valve stems sitting on my workbench where they will gather dust until sometime in July when my wheels arrive! You've got the more fun thing to look at while you wait :D
    CreoUCLA[QUOTED] likes this.
  18. May 12, 2021 at 6:54 PM
    #3038
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    To my surprise, my wheels came with valve stems. Like you, I bought them while I was waiting for the wheels to arrive.
  19. May 12, 2021 at 7:18 PM
    #3039
    Phich
    San Antonio
    Six Demon Bag
    Crap! $70 bucks that’ll be too late to return by the time the wheels arrive. Better safe than sorry though :cool:
  20. May 12, 2021 at 7:33 PM
    #3040
    CreoUCLA
    West L.A.
    True, as it took a long 8 months for them to arrive (I ordered these before I bought the Tacoma). :p
    Depending on how much longer the center caps/lug nuts take to arrive, I may just install them with a set of conical lug nuts from Amazon in the meantime. :thumbsup:
    Phich[QUOTED] likes this.
