Volt hid high beam not working anymore?
Discussion in 'Lighting' started by Tunajoe13, Nov 9, 2012.
  1. Nov 9, 2012 at 8:28 PM
    Tunajoe13
    Tunajoe13 [OP] Well-Known Member
    Joe
    Parrish, FL
    05’ Base V6 4x4 extended cab
    20'' wheels, 34''x11" Toyo Open Country A/T II tires, 4.88 Gears, ARB Locking Rear Diff, ARB compressor, Fiberglass bed cover, Weathertech floor liners, Weathertech side window protectors, Allpro Apex front bumper, Allpro Apex rear bumper Allpro 3'' Expo rear leaf kit, Allpro hidden hitch receiver, 10'' aluminum drop hitch, Camburg 4'' spindles, Allpro uniball uca's, Ottonavi 6.5'' touch screen G.P.S, 09' Tailgate with factory reverse camera, Stampede hood protector, Raptor style grill and hood mesh (Homertaco), Piaa 5100 Fog lights, Volt HID's, Viper5704 Alarm with remote start, Limo tint, Scangauge II, TRD cai, URD 3'' Mk2 exhaust, Doug Thorley LT headers, URD Y-pipe, Unichip PnP Pcm, Unichip Flux2 display, Factory Sport hood....
    Hi everyone, so i installed a set of bolt 6k HID's in my taco about 2 months ago... Everything went smooth and worked fine. both the low and high beams... Today i noticed the high beam wouldn't come on when I tried on my way home? Could I had damaged them by flashing other driver driving without their lights on? this is my first set of HID's
  2. Nov 9, 2012 at 8:38 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    There is only one bulb in there, sounds like your solenoid has quit working (it moves the little shield to let out more light).
  3. Nov 11, 2012 at 11:07 AM
    Tunajoe13
    Joe
    Parrish, FL
    thx! Now the light that wont work has switched to the passangers side?... Still thinking its the solenoids?
  4. Nov 11, 2012 at 11:07 AM
    Tunajoe13
    Joe
    Parrish, FL
    was thinking I might need a new battery...
  5. Nov 11, 2012 at 11:17 AM
    t4daddy
    North Alabama
    Just a guess here, but I'd say your harness is bad.
  6. Nov 11, 2012 at 11:28 AM
    Tunajoe13
    Joe
    Parrish, FL
    ok thx. I sent volt an e-mail but gotta wait till monday or later for a response. Hoping to fix this asap but if the parts are bunk I cant do anything about that. Just seems odd that its switching from one side to the other. heard one guy say on hear that he had a similar issue bc his battery diidnt have the power for all his electric accessories... Was hoping that was it lol.
  7. Nov 11, 2012 at 11:33 AM
    t4daddy
    North Alabama
    Try putting the "working" connector on the "non-working" bulb and see what happens. I don't think your battery is the problem.
  8. Nov 11, 2012 at 11:38 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    x2.
  9. Nov 11, 2012 at 11:46 AM
    Tunajoe13
    Joe
    Parrish, FL
    Thx! Sometimes its the passangers side that out and sometimes its the drivers side. Not trying to sound stupid but wouldnt that mean the harnesses are fine? I will try your idea though for sure
  10. Nov 11, 2012 at 12:17 PM
    t4daddy
    North Alabama
    To me, it sounds like it could be a short of sorts in the harness, I'm just fishing here. Your bulbs are good or not, they ain't going back and froth from good to bad.
  11. Nov 11, 2012 at 12:25 PM
    Tunajoe13
    Joe
    Parrish, FL
    thats what im thinking. bulbs are good im pretty sure bc they both do work just not at the same time...
  12. Nov 11, 2012 at 12:31 PM
    t4daddy
    North Alabama
    Last post you stated you thought harness was fine.
  13. Nov 11, 2012 at 12:34 PM
    Tunajoe13
    Joe
    Parrish, FL
    just a thought bc one both side do work but not at same time... drivers side works now. but yesterday it the passangers side that was working. wouldnt that mean the harnesses are ok? maybe I mis informed you srry
  14. Nov 11, 2012 at 12:55 PM
    t4daddy
    North Alabama
    To me, that means your harness has a short (something is grounding at times not at others). Bulbs are good, I'll wager.
  15. Nov 11, 2012 at 1:03 PM
    Tunajoe13
    Joe
    Parrish, FL
    roger that. I'll be switching them over and seeing what happens in the morning. Also i'll mess with the ground wirs and check all connections again. also gonna squirt come electro grease in the connectors to help with moister getting to them. Thanks again for your help and sorry is i was apita. lol
  16. Nov 14, 2012 at 5:43 AM
    Tunajoe13
    Joe
    Parrish, FL
    After speaking with a rep from kbcarstuff.com who was really confused when i told him my issue... I just unplugged and replugged all connections with bulb grease reconnected the grounds. Everything's working fine now and has been since monday. Im going to watch it though. Just thought id throw an update out there. thx again for your help t4daddy!
