Voltage sensing wire relocation
Discussion in 'Technical Chat' started by Spencer, Dec 5, 2015.
  1. Dec 15, 2015 at 9:53 PM
    Spencer
    Spencer [OP] Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Hahahahaha holy crap I should have known it came from a Tacomaworld guy! Thanks crom!
    I found the alternator bible and found that write-up on a totally different website. Someone took that whole thing and put it on its own webpage I had no idea it came from here.
    I'd like to get this project done soon and keep this thread for the relocation part alone for all the people running extra crap on a stock alt.
    Crom[QUOTED] likes this.
  2. Dec 16, 2015 at 5:55 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    The owner of the website you linked to and Mike aka Tacozord are the same person. He's new here at TW, and making great contributions. :thumbsup:
    Glad to help.
    Spencer[QUOTED][OP] likes this.
  3. Jan 14, 2016 at 10:31 PM
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    Which of the wires in the plug in @tacozord 's writeup is the voltage sensing wire?
  4. Jan 18, 2016 at 12:23 PM
    tacozord
    tacozord Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    Here's the link to the post in my build page where I did the Big-3 upgrade along with the voltage sense wire.
    https://www.tacomaworld.com/threads/boden-build-2015-dclb-4x4.362640/page-3#post-10274246
    Anyway, if you look at the following picture, I point out which wire is the voltage sense wire that connects to the alternator:
    This is the plug that connects to the alternator:
    According to the schematic, the white wire that comes out of this plug is the voltage sense wire. So just re-route this wire to wherever you want to sense voltage. (Notice the little "S" label where the wire attaches to the alternator, which is labeled as a generator.)
    There's more details in my build page at the link above. I hope this helps.
    harryn likes this.
  5. Jan 18, 2016 at 3:36 PM
    abarber11
    ATX
    2011 DCSB
    Yes great write up! I went thru it all and there was a lot of good info in there. Your post answers my question!
  6. Aug 8, 2017 at 4:54 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Bit of a bump here. I understand you want to put the voltage sensing wire where the demands are this way you get max charge.
    Could I put the voltage sensing wire straight to the starting battery? So move It from sensing at the alternator to the battery?
    Also, just to confirm, you take the white wire from the alternator plug and move it. So it may be a wire run from the battery to the fuse block for jnstance instead of the alternator to the fuse block.
  7. Aug 11, 2017 at 12:25 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Can't help you with VSW.
    But another way to accomplish this, that takes less than a minute, that is completely reversible and has worked well for me for 14 months.
    A Voltage Boosting Diode.
    It's a diode added to a resetable 7.5A fuse that installs in place of the factory voltage sensing fuse in the engine fuse block.
    Edit: A VBD is really only an option if you're running sealed AGM in both starting and secondary batteries or batteries that can take a tad higher voltage...
    I can explain it here, but the folks who build them will do a far better job:
    https://www.hkbelect.com/product/143-mk3-micro-blade-75a-electronic-fuse-version-2013/
    And to select which model and year:
    https://www.hkbelect.com/products/toyota/
    tacoma16[QUOTED] likes this.
  8. Aug 11, 2017 at 4:30 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Interesting. What were your before and after voltages?
  9. Aug 11, 2017 at 4:33 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Also, this says only .5-.6 v increase. For those that did relocate there vsw what was your increase? I'm sure it really depends on your draw I guess. But if the fuse only gives .5-.6 v and the draw on the system is more, than the vsw would still need to be relocated I think.
  10. Aug 11, 2017 at 6:24 PM
    License2Ill
    Ian
    Before was 13.5/14.0, very rarely 14.1
    Now it's 14.0-14.2/ 14.6-14.7.
    The higher numbers are cold start voltages or if the batteries SOC is low.
  11. Aug 11, 2017 at 6:34 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    That's not to shabby at all. Thanks for the heads!
    :cheers:
  12. Aug 18, 2017 at 11:39 AM
    tacozord
    2015 DCLB 4wd SR5
    This is incorrect. The wire still needs to be connected to the alternator. That's the point. The alternator is sensing the voltage at some location, which when low, tells the alternator to work or increase it's voltage output. Connecting the wire from the battery to the fuse block creates a short. You want to move the wire from the fuse block to some other location. For my setup, that was a positive busbar that fed the OEM fuse block as well as my Bussman RTMR.
  13. Aug 18, 2017 at 12:27 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    So you follow the white wire from the alternator plug. Remove it from the fuse box and put it where the demands are going to be higher? So everything is the same at the alternator, just the location of where the altnerator is getting its info is different.
  14. Aug 18, 2017 at 5:26 PM
    tacozord
    2015 DCLB 4wd SR5
    Yup!
  15. Aug 18, 2017 at 5:33 PM
    #35
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Thank you! Wanted to make sure 100% before chopping wires.
