Volume Control not always working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by d10k6, Jul 19, 2011.
  1. Jul 19, 2011 at 10:44 AM
    d10k6
    d10k6 [OP] Member
    Fredericton, NB
    09 Double Cab TRD Sport, Silver Streak
    Recently I have noticed that the volume control knob on my 2009 TRD Sport with stock radio (no bluetooth) does not always work. If you turn the knob, nothing happens.
    The hand controls on the steering wheel work fine.
    The weird thing is that sometimes the volume control will work, if it does work it will work for the entire time the truck is ON but sometimes when started back up it is back to not working.
    This seems like more of a "software" issue than a broken knob issue but I am not sure.
    Has anyone else experienced this or heard of it?
    Thanks!
    ~d10
  2. Jul 21, 2011 at 10:18 AM
    The Wombat
    The Wombat Active Member
    Mass.
    09 Access Cab 4WD 4-cyl
    none
    yup - mine does the same thing. Sometimes it just wigs out and turns itself on/off, sometimes the display all goes to shit and displays gobbledygook. Dealer wouldn't do anything unless they saw it happen, and of course it's intermittent, so i'm stuck with it.
    Probably just go aftermarket before too long.
  3. Jul 21, 2011 at 10:24 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Yes its a known issue. You can take it back to the dealership or do what alot of us have done and get an aftermarket unit.
  4. Jul 21, 2011 at 10:29 AM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
    Known issue with 2009 radios. As said before you can get it replaced if you're under warranty or go with an aftermarket unit. I had mine replaced soon after I bought it and just replaced it again a few months ago.
  5. Jul 21, 2011 at 10:43 AM
    fauskar
    fauskar Active Member
    Rick
    Wisconsin
    SR5
    Hitch
    Same here, 2009... radio volume control would stop working. Replaced under warranty 1 year ago and no problems since.
  6. Jul 22, 2011 at 11:02 AM
    d10k6
    d10k6 [OP] Member
    Fredericton, NB
    Anyone know if I can just upgrade to the bluetooth model and pay the difference? It is still under warranty
