Volume Knob Quirk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AZ TXPRO, Jul 4, 2013.
  1. Aug 1, 2016 at 6:59 PM
    DrFunker
    DrFunker Well-Known Member
    o0oSHADOWo0o likes this.
  2. Aug 1, 2016 at 8:00 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Sounds like a bunch of people are having problems with their knobs. They make a pill for that don't they? :rolleyes:
    I'm not going to boast and say mine goes to eleven, but it goes high enough. :D
    DrFunker[QUOTED] likes this.
  3. Aug 1, 2016 at 8:02 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Spinal Tap Rocks!
  4. Aug 1, 2016 at 10:14 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    My 2011 JBL volume knob does not have notches either, only the tuning knob does.
  5. Aug 1, 2016 at 11:02 PM
    Tacoma005
    Tacoma005 Well-Known Member
    Bellingham, WA
    2005 DCSB TRD Off-Road 4X4
    KMC Crank Rims, 30" Baja Designs light bar, HomerTaco front grill
    My 05 volume knob just started acting up also.
  6. Aug 2, 2016 at 3:22 AM
    DrFunker
    :laugh:
    :cheers:
  7. Sep 1, 2016 at 5:59 AM
    jSINb
    jSINb New Member
    2008 blue tacoma prerunner
    Sorry if I'm opening a dead thread but was there ever a solution found for this volume button problem? Mine does the same thing as originally poster stated. Turn volume up and sometimes it goes down and vise versa. Really have to play with it to get the desired volume. Removed knob and it's all in tact which leads me to believe its an internal problem.
  8. Sep 1, 2016 at 6:49 AM
    David K
    Just use the volume up and down buttons on the steering wheel... it overrides the radio knob (which like some of yours does no react instantly when turned... even gets louder a bit while trying to turn it down. It seems to be a digital vs. analog thing... use the up/down buttons instead.
  9. Sep 1, 2016 at 7:31 AM
    jSINb
    jSINb New Member
    Thanks for the reply. Unfortunately, I do not have volume control on my steering wheel. I guess I'm left to just gingerly adjust the volume until I'm forced to buy a replacement radio. Really annoying though lol.
  10. Sep 1, 2016 at 7:54 AM
    David K
    Oh really? I figured the radio volume knob didn't work instantly because of the hands on wheel controls?
  11. Sep 1, 2016 at 11:26 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    I cant use my knob on my 09 anymore...turning down turns it up...have to use the steering wheel...or if I get a call or something I just have to turn the radio off
  12. Sep 1, 2016 at 3:08 PM
    Toyojake
    Toyojake Well-Known Member
    Jay
    Central TX
    2009 T4R Sport 4x4
    My 2009 has done this for as long as I can remember. I believe it to be caused by the contacts between the faceplate and the main body getting loose in the heat. Quick fix is to push in with medium pressure towards the firewall on the face, above the CD slot. Pushing the connector back in slightly.
    Always does the trick in my truck, but it happens again after a month or so.
    Hope that helps.
  13. Sep 2, 2016 at 7:31 AM
    Chris24
    Greensboro, NC
    interesting, i'll have to try this.
  14. Sep 2, 2016 at 7:27 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Or save yourself the trouble and just go to aftermarket. A $60 aftermarket radio will work well forever. Toyota can't do the simplest crap...
    DaveB.inVa likes this.
  15. Sep 6, 2016 at 9:00 AM
    #35
    Chris24
    Greensboro, NC
    Tried this yesterday, no luck for my truck :(
  16. Sep 6, 2016 at 9:13 AM
    #36
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    My 09 has the same quirk. Can be quite annoying at time, even with the controls on the wheel.
    Chris24 likes this.
  17. Mar 8, 2017 at 9:15 PM
    #37
    jjjasper
    jjjasper New Member
    Jasper
    '09 Tacoma PreRunner
    Solved - fixed - it was too simple
    Pulled volume knob off
    Sprayed Deoxit D5 Contact Cleaner- tiny pulse on low (can comes with 3 settings)
    Spun around a few times
    viola - now works like a charm
    I Got it on amazon: Hosa D5S-6 CAIG DeoxIT 5% Spray Contact Cleaner, 5 oz.
    Probably any spray contact cleaner from Radio Shack or Electronics shops will work
    Cemejose, mjhebert, mpm and 1 other person like this.
  18. Mar 9, 2017 at 4:40 PM
    #38
    Mr. Noun
    Mr. Noun Member
    Oklahoma
    09 DCSB 4X4 Base
    ^^^ This! I've had this problem in my 2009 dcsb base model stereo for the past year and it was driving me slowly nuts.
    Yanked the plastic knob off the stereo and sprayed a quick shot of a random contact cleaner I had in my garage in the hole. Pressed the knob back on and everything works again.
    mpm and duvinclunk like this.
  19. Feb 2, 2019 at 5:03 PM
    #39
    Cemejose
    Cemejose Member
    09 Tacoma TRD Off Road
    I was having the same issue in my stock jbl head unit. Bought the Hosa mentioned above and sprayed in the volume know hole and it works. My radio's volume is not skipping and works perfectly .
  20. Feb 3, 2019 at 8:08 AM
    #40
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Mine has does this since I purchased the truck. I'm pretty sure it's just the potentiometer needing cleaning. But I haven't had time or the patience to try to figure out how to get to it.
