Volume needed to drown out rear diff howl
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacowin1013, May 5, 2017.
  1. May 5, 2017 at 6:41 AM
    Tacowin1013
    Tacowin1013 [OP] Well-Known Member
    2017 OR DCSB 6MT MGM
    Curious if those with a rear diff howl have tried to measure the noise level (not frequency) by seeing what radio volume is needed to drown out the noise---mine started at 500miles and around 35 on my radio. Now at 1000 miles and it seems to have increased to 40. JBL isn't available on the M/T so i know the numbers will differ with those builds but still curious how loud some of these are getting. Or are we just seeing a broader speed range when feathering
    scottalot, Kyitty and shakerhood like this.
  2. May 5, 2017 at 6:50 AM
    Taco16LB
    Taco16LB Well-Known Member
    This is very interesting . I have a slight howl but If I turn the radio on at all I do not here the howl . I have a DC long box OR and this makes the drive angles different than the DCSB trucks . Ever since @smitty99 did his 1 1/2 " lift his howl almost went away and is wondering if it is not fully the rear end ? My noise has been the same from when I first heard it at around 2K until now at 7K .
    Rowdymoon and smitty99 like this.
  3. May 5, 2017 at 6:52 AM
    Tacowin1013
    Just thought about it on my way to work this morning so I thought I would get TWs opinions. But I know everyones hearing is different and it may also be that I'm "listening" for it as well so I'm hearing something that most would not
  4. May 5, 2017 at 6:59 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    ChadsPride likes this.
  5. May 5, 2017 at 8:22 AM
    stevenwhite1989
    stevenwhite1989 Well-Known Member
    30 with XM, 25 with BT, or just open all four windows for me...
  6. May 5, 2017 at 8:27 AM
    Tacowin1013
    I thought about a poll but there's simply too many variables to standardize the volume across the board. But yes i do notice that XM requires a little higher than FM radio. I have been using XM but i will see what FM levels are this afternoon
  7. May 5, 2017 at 8:30 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    You guys realize that having a howl there is something wrong with your diff(most likely) or trans right? Drowning out the noise to ignore it is pretty fuckin stupid
    TacoBill92656 and smitty99 like this.
  8. May 5, 2017 at 8:35 AM
    Tacowin1013
    Oh really? Gee thanks for letting us know this!
  9. May 5, 2017 at 8:37 AM
    airborndad
    airborndad Well-Known Member
    Keith
    Montclair, CA
    2017 Black DCLB TRD Off Road 4X4 JBL
    Front Runner Slimline Roof Rack
    Go to the dealership start low and work your way up to full volume until they understand that you think this is unacceptable
    Hope it all works out for you
    Good luck
    smitty99 likes this.
  10. May 5, 2017 at 8:38 AM
    Taco16LB
    Only reason to drown it out for this thread to see how loud the noise is as compared to other trucks. I have considered my howl slight , maybe it is as loud as most others.
    shakerhood likes this.
  11. May 5, 2017 at 8:41 AM
    Tacowin1013
    Waiting for my 5k service to let them know about the howling noise--for now, me and everyone else on this forum knows it's not normal behavior so trolling to tell us that its not normal seems pretty redundant.
    Taco16LB likes this.
  12. May 5, 2017 at 8:44 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Says the guy with the '09 :smack: Unless you've been living under a rock, you'd know that 3rd gens have a howling diff and Toyota has no fix for it aside from the recall.
  13. May 5, 2017 at 8:46 AM
    stevenwhite1989
    We are well aware of the fact that there is something wrong with the diff. Toyota Corporate has told me literally "...the truck is operating as engineered".
    smitty99 and shakerhood like this.
  14. May 5, 2017 at 8:47 AM
    Taco16LB
    I already had mine in to have it checked at my 5K and they could not , would not admit to hearing it.
  15. May 5, 2017 at 8:49 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My trucks rear diff started howling just after 300 miles, now around 1,300 miles the sound is no louder but the mph range increased. Never paid attention to the radio volume but will report back after I remember to check. I notice the sound is loudest when going down a long hill and feathering the throttle.
    smitty99 and Taco16LB like this.
  16. May 5, 2017 at 8:53 AM
    ARCOVT16
    ARCOVT16 Well-Known Member
    VT
    2016 DCLB SR5
    Icon ext Travel Coilovers, SPC UCA, SCS 16x8 Wheels, 285/75r16 G003, Toytec 3leaf AAL, Icon 2.0 Remote Reservior, Toytec Axle shims, Toytec Front Diff drop, Timbren U-Bolt flip kit, Clazzio Black Seat covers.
    Does this howl sound anything like worn AT tires or mud tires on asphalt?
  17. May 5, 2017 at 9:40 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Wake up! Hello! Yes it is an issue on Sport and SR5 Trims included. This is very well covered and discussed ad nauseam in the 3rd Gen Howling Poll thread.
  18. May 5, 2017 at 9:41 AM
    shakerhood
    Southern Ohio
    I think you are correct that it is mostly OR, however there have been other models with it too, also think the 8.75 is used in models with manuals just without the locker.
  19. May 5, 2017 at 12:56 PM
    Basikbiker
    Trav
    Yea this guy also has extensive knowledge of ring and pinion setups, and trucks in general....I built my entire rear end buddy
    toyguyic and smitty99 like this.
  20. May 5, 2017 at 12:58 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I ain't your buddy, pal.
    Lawfarin likes this.
